Gigabit interface can't go to 1000Mb/s
boban-petrovic
I have a 2960 with a following relevant config:
interface Port-channel1
switchport mode trunk
interface GigabitEthernet0/1
channel-group 1 mode active
interface GigabitEthernet0/2
bandwidth 1000000
And stacked 3750's with relevant config:
interface Port-channel8
interface GigabitEthernet1/0/24
channel-group 8 mode active
interface GigabitEthernet2/0/24
bandwidth 1000000
Port gi0/1 is connected to gi1/0/24, and gi0/2 is connected to gi2/0/24
When I check channel groups, I see:
Group  Port-channel  Protocol    Ports
8      Po8(SU)         LACP      Gi1/0/24(P) Gi2/0/24(s)
So port 2/0/24 is in suspended mode. It's the same on 2960
Details are:
3750#sh etherchannel 8 detail
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
        Ports in the group:
Port: Gi1/0/24
Port state    = Up Mstr Assoc In-Bndl
Channel group = 8           Mode = Active          Gcchange = -
Port-channel  = Po8         GC   =   -             Pseudo port-channel = Po8
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/0/24  SA      bndl      32768         0x8       0x8     0x119       0x3D
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Gi1/0/24  SA      32768     0021.56a4.3000   5s    0x0    0x1    0x19    0x3D
Age of the port in the current state: 0d:19h:34m:40s
Port: Gi2/0/24
Port state    = Up Cnt-bndl Suspend Not-in-Bndl
Port-channel  = null        GC   =   -             Pseudo port-channel = Po8
Local information:
Gi2/0/24  SA      susp      32768         0x8       0x0     0x219       0x45
Age of the port in the current state: 0d:00h:20m:37s
Probable reason: speed of Gi2/0/24 is 100M, Gi1/0/24 is 1000M
        Port-channels in the group:
Port-channel: Po8    (Primary Aggregator)
Age of the Port-channel   = 0d:19h:51m:12s
Logical slot/port   = 10/8          Number of ports = 1
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi1/0/24 Active             0
Time since last port bundled:    0d:19h:34m:43s    Gi1/0/24
3750#sh int gi2/0/24
GigabitEthernet2/0/24 is up, line protocol is down (suspended)
  Hardware is Gigabit Ethernet, address is 0017.946f.0798 (bia 0017.946f.0798)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
2960#sh int gi0/2
GigabitEthernet0/2 is up, line protocol is down (suspended)
  Hardware is Gigabit Ethernet, address is 0021.56a4.301a (bia 0021.56a4.301a)
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
If I do "speed 1000" on 3750, gi0/2 on 2960 goes down, although gi0/2 support 1000Mb/s.
How to solve this?
Giuseppe Larosa
Hello Boban,
1000 Mbps operation requires a cable with all four pairs
try to change the cable between C2960:gi0/2 and C3750, first of all remove port channel configuration do shut/no shut interfaces an check if you are able to see both links running at 1000 Mbps before applying port channel configuration again
Eventually swap the cabling and check if the problem follows the cable.
Edit:
to force the speed manually you have to do it on both sides, but it is not recommended with gigabit ethernet
Hope to help
Giuseppe
10 Replies 10
Giuseppe Larosa
Hello Boban,
Edit:
Hope to help
Giuseppe
Hello Boban,
Nope.  All you need is three.  If you run the TDR, you need only A, B and D.  Pair C controlls PoE and Pair D controls GigabitEthernet.
Hello Leo,
as far as I know 802.3ab uses 4 pairs, PoE is a different matter
see
http://en.wikipedia.org/wiki/Gigabit_Ethernet
Hope to help
Giuseppe
I ain't going to debate on you with this because I know you are right.  I was, however, talking about the TDR results taken from a Cisco switch.
Leo Laohoo
Run TDR on both switches.  Here are the commands:
1.  Command:  test cable tdr interface ;
2.  Wait for approximately 5 to 7 seconds;
3.  Command:  sh cable tdr interface ;  and
4.  Please post the output to the command.
3750#show cable-diagnostics tdr interface gigabitEthernet 2/0/24
TDR test last run on: May 15 11:10:27
Interface Speed Local pair Pair length        Remote pair Pair status
Gi2/0/24  auto  Pair A     2    +/- 4  meters Pair B      Normal
                Pair B     2    +/- 4  meters Pair A      Normal
                Pair C     0    +/- 4  meters Pair C      Open
                Pair D     0    +/- 4  meters Pair D      Open
2960#sh cable-diagnostics tdr interface gi0/2
TDR test last run on: May 15 11:09:11
Gi0/2     100M  Pair A     N/A                Pair A      Normal
                Pair B     N/A                Pair B      Normal
                Pair C     4    +/- 2  meters Pair C      Open
                Pair D     4    +/- 2  meters Pair D      Open
Giuseppe is right.  The output from both switches is showing that Pair "D" is in Open Circuit.  Pair "D" controls GigabitEthernet.   This is why the interface will only negotiate to 100 Mbps.
Change the patch cable.
You could also issue show connect status to find out how the auto negotiation had worked and at what speed they have settled down at ... that would give us a fair idea about on which speed the both ends are operating and negotiated.
Just my 2 cents.
-Vijay
There is no "show connect status" command...
  He meant "show interface status"  .
