GigabitEthernet2/0/1 is down, line protocol is down (monitoring)
LAAsm2012b
Csico switch 3750, when connect a device to this port, the light on the switch is green, but the device doesn't get IP, and doesn see it belongs to any VLAN in sh vlan.
sh int g2/0/1 got:
  Hardware is Gigabit Ethernet, address is x.x..x (bia x.x.x)
  MTU 5000 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:34:41, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 209
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     39158 packets output, 13651510 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
can anyone pls tell me how to fix this? thx.
Peter Paluch
According to the output, the port is a part of a monitor session (a SPAN session) as a destination port. Look for "monitor session" commands in your configuration that refer to the port, and if you do not need this monitoring session, you may remove it from your configuration. That will make the port work normally again.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
