glbp configuration
cfajardo1_2
Level 7
Level 7
scenario;
-2x6500 with fwsm on each
-msfc with user vlans 12,13 running glbp
-no trunk connections between the 2x6500
-user edge switch having trunk connections to both of the core
CORE CONFIG
CORE 1
int vlan 101
ip address 192.168.101.1 255.255.255.0
glbp 101 ip 192.168.101.254
glbp 101 priority 110
CORE 2
int vlan 101
ip address 192.168.101.2 255.255.255.0
glbp 101 priority 105
QUESTION;
-why if i removed 1 one of the uplink on the edge, my connection get lost and will never come back.
jaye15394
Level 3
Level 3
You say you have glbp running on vlans 12,13. Where is that configuration?
The config is only showing GLBP for VLAN 101 on the core.
Jason
sorry. it is same as the vlan 101 config.
