glbp
CSCO10456946
Community Member
I have this configuration on two routers:
Router 1
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.120.254 255.255.255.0 secondary
ip address 10.1.6.163 255.255.248.0
ip helper-address 10.4.0.51
ip helper-address 10.4.0.52
ip accounting output-packets
ip accounting access-violations
service-policy input MARKING
no ip mroute-cache
no cdp enable
glbp 10 ip 10.1.6.162
glbp 10 ip 10.1.120.1 secondary
glbp 10 preempt
glbp 10 load-balancing weighted
Router 2
ip address 10.1.120.253 255.255.255.0 secondary
ip address 10.1.6.164 255.255.248.0
no ip mroute-cache
no cdp enable
glbp 10 priority 254
glbp 10 preempt
end
but a show glbp int show that just one forwarder is active int group:
sh glbp f0/0.1
FastEthernet0/0.1 - Group 10
State is Active
7 state changes, last state change 1w3d
Virtual IP address is 10.1.6.162
Secondary virtual IP address 10.1.120.1
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.520 secs
Redirect time 600 sec, forwarder time-out 14400 sec
Preemption enabled, min delay 0 sec
Active is local
Standby is 10.1.6.163, priority 100 (expires in 9.480 sec)
Priority 254 (configured)
Weighting 100 (default 100), thresholds: lower 1, upper 100
Load balancing: weighted
There are 2 forwarders (1 active)
Forwarder 1
State is Listen
2 state changes, last state change 1w4d
MAC address is 0007.b400.0a01 (learnt)
Owner ID is 0002.2c80.4100
Redirection enabled, 599.476 sec remaining (maximum 600 sec)
Time to live: 14399.476 sec (maximum 14400 sec)
Preemption enabled, min delay 30 sec
Active is 10.1.6.163 (primary), weighting 100 (expires in 9.476 sec)
Arp replies sent: 80876
Forwarder 2
State is Active
5 state changes, last state change 1w3d
MAC address is 0007.b400.0a02 (default)
Owner ID is 0002.2c79.e000
Redirection enabled
Active is local, weighting 100
Arp replies sent: 80874
In this case I don't have load balancing.
Someone can give my an advice?
dan-jones
Level 2
Level 2
Have you tried leaving the 'glbp 10 priority 254' statement off router 2 to see if it impacts glbp at all?
odegbenga
Community Member
glbp will just route traffic to both routers but dis will be done on the weight u specify.for example in your sample, if one packet goes to one router about 2.5 will go to the next router. it is simply routing over un-equal path here, kind of. If u want load-sharing u either use a 3rd-vendor like f5 or u use cisco oer.
