GLC-LH-SM transciever - Problem in Extended Ping
farhan.engr
I have installed two 1000BASE-LX/LH SFP (GLC-LH-SM) each with Cisco SF300-24 and Cisco 2960 in order to establish a backbone connectivity between two departments. The distance between the two departments is around 600 metres
Normal Ping Response is fine as per the below output (highlighted in GREEN):
C:\Users\Admin>ping 145.17.62.148
Pinging 145.17.62.148 with 32 bytes of data:
Reply from 145.17.62.148: bytes=32 time=5ms TTL=63
Reply from 145.17.62.148: bytes=32 time=1ms TTL=63
Ping statistics for 145.17.62.148:
     Packets: Sent = 217, Received = 217, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
     Minimum = 1ms, Maximum = 7ms, Average = 1ms
But when I do and Extended Ping between the Switches then I'm getting the following response (highlighted in GREEN):
Test-1#ping
Protocol [ip]:
Target IP address: 145.17.62.148
Repeat count [5]: 500
Datagram size [100]: 18024
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 500, 18024-byte ICMP Echos to 145.17.62.148, timeout is 2 seconds:
Success rate is 81 percent (407/500), round-trip min/avg/max = 16/24/42 ms
Can someone please help me on this?
Farhan.
patrick.preuss
Hi Farhan
Can you provide a Show Interface ?
Can you Run cable diagnostics?
Patrick
Dear Patrick,
Please see the following response and advice.
TEST-1#test cable-diagnostics tdr int gi0/1
% Set 'media-type rj45' to run TDR test on interface Gi0/1
TEST-1#sh cab
TEST-1#sh cable-diagnostics tdr
TEST-1#sh cable-diagnostics tdr int
TEST-1#sh cable-diagnostics tdr interface gi 0/1
% TDR test was never run on Gi0/1
TEST-1#sh int
TEST-1#sh interfaces gi 0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e8ba.7014.5899 (bia e8ba.7014.5899)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:09, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:12:16
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 334000 bits/sec, 111 packets/sec
  5 minute output rate 443000 bits/sec, 115 packets/sec
     75857 packets input, 27886158 bytes, 0 no buffer
     Received 1184 broadcasts (621 multicasts)
     0 watchdog, 621 multicast, 0 pause input
     80161 packets output, 38763382 bytes, 0 underruns
Farhan
Dear,
If anybody can help with the above stated issue, I would be really thankful.
Farhan.
