Requirements for line card upgrade on WS-C6509-E
saadat661
We are planning to replace a few line cards in the existing 6509-E chassis. The sup installed is a VS-S720-10G-3C but the line cards are legacy. As a result we are not able to enable the VSS functionality.
We are looking to replace the existing line cards with the following:
1. 1 x WS-X6716-10G-3C
2. 1 x WS-X6724-SFP
3. 4 x WS-X6724-GE-TX
Could somebody kindly tell me about the requirements in terms of IOS and ROMMON.
The current IOS is:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI2a, RELEASE SOFTWARE (fc2)
And the ROM Version is:
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Do I need an upgrade?
Thank you.
Andras Dosztal
Level 3
Level 3
VSS is supported from IOS 12.2(33)SXH1. I don't know if there's a minimum required ROMMON version.
Thank you Andras
Scott Hodgdon
Those modules will work with the code you have.
The Catalyst 6500 IOS Release Notes talk abaout minimum ROMMON version on the module for these two modules:
Use with Release  12.2(33)SXH or later requires switching module ROMMON version  12.2(18r)S1 or later. To display the switching module ROMMON version,  enter the remote command module module_slot_number show version | include ROM command. To upgrade the switching module ROMMON, see this document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/rommon/OL_6143.html
Release notee link :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/hardware.html#wp2681003
Keep in mind that there is ROMMON on the Supervisor and ROMMON on the module, and they are not necessarily the same.
