Hi !
GLC-SX-MMD module not detecting in 4500-X switch running with 3.8.6 IOS version. Not listed in "Show interface transceiver".
Same Module working fine with 3650 Switches. Has anyone come across this issue??
Thanks in Advance
according to the compatibility matrix (attached) the transceiver is supported on the 4500X. Try:
4500X(config)#service unsupported-transceiver
do you see any logs when you insert this SFP ?
