GLC-TE compatibility with 4500-x
StefanDietrich
Can anyone confirm me, if the new GLC-TE 1GE SFPs run well with 1000Mbit in a SFP+ port on the 4500-X? I don't see this SFP listed in the SFP compatibility matrix, which seems to be strange as the GLC-T is supported on the 4500-X (with both 10/100 and 1000Mbit)
Regards/
Stefan
8 Replies 8
Julio E. Moisa
It is the list of SFP supported on 4500X
It is not supported on "X" models just on some Catalyst 4500 modules like: WS-X4516-10GE
Reference: http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc476298541
Network Device
Transceiver Module
Minimum Software Release Required
Cisco IOS Support
DOM Support
WS-C4500X-32SFP+
WS-C4500X-F-32SFP+
WS-C4500X-40X-ES
C4KX-NM-8SFP+
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
3.3.0SG
GLC-T (10/100)
3.7.1E
GLC-SX-MMD
GLC-LH-SMD
GLC-ZX-SMD
3.3.0SG
3.7.2E
GLC-BX-D
GLC-BX-U
CWDM SFP
DWDM SFP
DWDM SFP (add.)
3.3.0SG
3.3.0SG
GLC-BX40-D-I
GLC-BX80-D-I
GLC-BX40-U-I
GLC-BX80-U-I
GLC-BX40-DA-I
3.8.0E
3.8.0E
GLC-EX-SMD1
(CPN 10-2624-01
or later only)
3.4.1SG
3.4.1SG
WS-C4500X-16SFP+
WS-C4500X-F-16SFP+
WS-C4500X-24X-ES
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
3.3.1SG
GLC-T (10/100)
3.7.1E
GLC-SX-MMD
GLC-LH-SMD
GLC-ZX-SMD
3.3.1SG
3.7.2E
GLC-BX-D
GLC-BX-U
CWDM SFP
DWDM SFP
DWDM SFP (add.)
3.3.1SG
3.3.1SG
GLC-BX40-D-I
GLC-BX80-D-I
GLC-BX40-U-I
GLC-BX80-U-I
GLC-BX40-DA-I
3.8.0E
3.8.0E
GLC-EX-SMD1
3.4.1SG
3.4.1SG
Please rate the comment if it was useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, this was the list I also found, but I am wondering that the GLC-TE SFP is not listed for the 4500-X, as I thought that the hardware team designed this part to be fully backwards compatible with GLC-T. Has any one experience with this and has the GLC-TE running on a 4500-X? Probably the documentation wasn't updated...
No, unfortunately I have not used SFP GLC-TE, checking the link it was revised May 1. It looks like some modules support this SFP.
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
Revised: May 1, 2017
No one here else, who tried to get the GLC-TE running in a 4500-x??
Hi Stefan,
I have not tried it, but the GLC-T went EoS (since 1st June) so I guess the GLC-TE is the obvious replacement. I would also like Cisco to confirm this.
Incidentally, I understand there are limitations with negotiation on copper SFPs with the 4500X platform - see this post.
James.
I hear from Cisco that the GLC-TE support is planned on the 4500X platform (in a currently unreleased IOS-XE version).
Hope this helps
James.
Hello, I just tried those SFPs and when the SFP is from china it works perfectly but from Malaysia they do not.
Rasing
I had the same question and reached out to Cisco a while ago and they said it was supported, but up until now I was unable to see it in the documentation. You'll need IOS 3.8.4E according to the documentation.
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc490141220
