Nexus 9K does it support LDP ?
troxad
I'm trying to enable feature mpls ldp and the OS (9.3) doesn't recognize it. Is there an OS version that does or is that not available on a 9K. Googling hasn't been helpful.
I don't exactly know how to set up MPLS static between LDP talkers where the range of MPLS labels could be a lot... Would just the entire range work?
Thanks in advance!
M02@rt37
b.winter
What has your question to do with "Collaboration"?
@troxad I moved your post over to the Switching section of the community as it’s more suited for your question.
Response Signature
Share exact nsk platform you have and nx-os.
Note:- if you can delete this post and add new one in Switch category.
