Bookmark
Subscribe
2780
GNS3 Sporadic LAN Connectivity
marksargent
Hi All,
I'm using GNS3 0.8.2 on Win7. I have created a local network cloud and given a 7200 an IP of 10.1.1.10/24. ADSL router on this network is at 10.1.1.1. The Win7 machine is at 10.1.1.2. A Linux VM on VMware Server 2.0, on a bridged e1000 is at 10.1.1.4. I can ping 10.1.1.10 from 10.1.1.4 and vice-versa, but cannot ping 10.1.1.1 from either. I also cannot ping 10.1.1.2 from either, and weirder, from the Win7 command prompt, it cannot ping itself on 10.1.1.2 but can ping 10.1.1.1 or 10.1.1.4. I'm considering rebooting the Win7 host machine, but if anyone has any other suggestion, that'd be good. Thanks.
ADSL Router 10.1.1.1
Win7 10.1.1.2
Linux VM on Win7 10.1.1.4
7200 in GNS3 10.1.1.10
Mark
8 Replies 8
cadet alain
Can you put your NIC as a private network profile on the Windows 7.
Regards.
Alain.
Hi Alain,
apologies, forgot to mention, windows firewall is disabled. I am running a free zonealarm app, but even with it disabled too, problem still exists. Thanks.
Mark
Hi Mark,
Did you verify the network profile  is private though ?
Regards.
Alain.
Below shows the network types. I hope that is what you wanted to see. Thanks.
Mark
yes that was what I wanted to see. Can you provide a screenshot of the GNS3 topology with the cloud connection.
what is the arp cache on the router telling about the Windows 7 mac address? what is a debug ip pack detail 101 along with access-list 101 permit icmp any any is telling when pinginh the Windows 7 from the router ?
Can you also provide ipconfig and netstat -rn output from the Windows machine.
Regards.
Alain
The ADSL router is not a cisco router where I can insert the access-list you suggest, although I do have cli access to the shell. I disabled/enabled the problem connection to no avail. I'm suspecting it's local to the host machine as it cannot ping itself but has no issue pinging the ADSL router or the linux VM. As you can see from the output, it could at one time ping it's own IP, but then just hangs on the 2nd attempt and continues to do so. Thanks.
Mark
# arp
Address                  HWtype  HWaddress           Flags Mask            Iface
10.1.1.6                 ether   00:22:75:F2:3B:30   C                     br0
10.1.1.2                 ether   BC:AE:C5:6D:20:0B   C                     br0
# ping 10.1.1.2
PING 10.1.1.2 (10.1.1.2): 56 data bytes
64 bytes from 10.1.1.2: icmp_seq=0 ttl=128 time=0.0 ms
64 bytes from 10.1.1.2: icmp_seq=1 ttl=128 time=0.0 ms
64 bytes from 10.1.1.2: icmp_seq=2 ttl=128 time=0.0 ms
64 bytes from 10.1.1.2: icmp_seq=3 ttl=128 time=0.0 ms
64 bytes from 10.1.1.2: icmp_seq=4 ttl=128 time=0.0 ms
--- 10.1.1.2 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.0/0.0/0.0 ms
# arp
Connection to host lost.
C:\Users\Mark>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 10.1.1.1: bytes=32 time=14ms TTL=255
Reply from 10.1.1.1: bytes=32 time=7ms TTL=255
Ping statistics for 10.1.1.1:
    Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 7ms, Maximum = 14ms, Average = 10ms
Control-C
^C
C:\Users\Mark>ping 10.1.1.2
Pinging 10.1.1.2 with 32 bytes of data:
Control-C
^C
C:\Users\Mark>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::f0e2:f04:878a:7844%11
   IPv4 Address. . . . . . . . . . . : 10.1.1.2
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 10.1.1.1
Ethernet adapter VMware Network Adapter VMnet1:
   Link-local IPv6 Address . . . . . : fe80::cc1b:14e5:1906:df5f%16
   IPv4 Address. . . . . . . . . . . : 192.168.193.1
Ethernet adapter VMware Network Adapter VMnet8:
   Link-local IPv6 Address . . . . . : fe80::e8e8:3f3c:6fab:984d%17
   IPv4 Address. . . . . . . . . . . : 192.168.85.1
Tunnel adapter isatap.{42929810-6959-45F7-9500-BAE17466D29F}:
   Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter isatap.{8B1BB3B1-6182-4214-8794-5FC20B26F8CC}:
Tunnel adapter isatap.{A105DD13-D001-4FAD-BC5A-D50AE2244003}:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   IPv6 Address. . . . . . . . . . . : 2001:0:9d38:953c:14f5:3f1:8356:65d9
   Link-local IPv6 Address . . . . . : fe80::14f5:3f1:8356:65d9%14
   Default Gateway . . . . . . . . . : ::
C:\Users\Mark>netstat -rn
Interface List
11...bc ae c5 6d 20 0b ......Realtek PCIe GBE Family Controller
16...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
17...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
  1...........................Software Loopback Interface 1
12...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
14...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0         10.1.1.1         10.1.1.2     20
         10.1.1.0    255.255.255.0         On-link          10.1.1.2    276
         10.1.1.2  255.255.255.255         On-link          10.1.1.2    276
       10.1.1.255  255.255.255.255         On-link          10.1.1.2    276
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
     192.168.85.0    255.255.255.0         On-link      192.168.85.1    276
     192.168.85.1  255.255.255.255         On-link      192.168.85.1    276
   192.168.85.255  255.255.255.255         On-link      192.168.85.1    276
    192.168.193.0    255.255.255.0         On-link     192.168.193.1    276
    192.168.193.1  255.255.255.255         On-link     192.168.193.1    276
  192.168.193.255  255.255.255.255         On-link     192.168.193.1    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link          10.1.1.2    276
        224.0.0.0        240.0.0.0         On-link     192.168.193.1    276
        224.0.0.0        240.0.0.0         On-link      192.168.85.1    276
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link          10.1.1.2    276
  255.255.255.255  255.255.255.255         On-link     192.168.193.1    276
  255.255.255.255  255.255.255.255         On-link      192.168.85.1    276
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
If Metric Network Destination      Gateway
14     58 ::/0                     On-link
  1    306 ::1/128                  On-link
14     58 2001::/32                On-link
14    306 2001:0:9d38:953c:14f5:3f1:8356:65d9/128
                                    On-link
11    276 fe80::/64                On-link
16    276 fe80::/64                On-link
17    276 fe80::/64                On-link
14    306 fe80::/64                On-link
14    306 fe80::14f5:3f1:8356:65d9/128
                                    On-link
16    276 fe80::cc1b:14e5:1906:df5f/128
                                    On-link
17    276 fe80::e8e8:3f3c:6fab:984d/128
                                    On-link
11    276 fe80::f0e2:f04:878a:7844/128
                                    On-link
  1    306 ff00::/8                 On-link
14    306 ff00::/8                 On-link
11    276 ff00::/8                 On-link
16    276 ff00::/8                 On-link
17    276 ff00::/8                 On-link
Persistent Routes:
  None
C:\Users\Mark>
System reboot has not resolved the issue of pinging itself, but I can now ping 10.1.1.2 from both the ADSL router, 10.1.1.1, and the linux VM, 10.1.1.4. I can also ping from the GNS3 R1 to the linux VM and the ADSL router but not the host IP 10.1.1.2. Thanks.
Mark
Put the host machine into "sleep" mode overnight and when waking it up, I can no longer ping from the linux VM to the ADSL router or R1 in GNS3. Can ping the host machine on 10.1.1.2, though. Still the host machine cannot ping itself but it can ping the ADSL router and linux vm. It cannot ping Syd1 router in GNS3. Syd1 cannot ping anyone now. Weird. Thanks.
Mark
