Gratuitous ARP problem
cleetusant
Level 2
Level 2
My Cisco 3750 Catalyst switch is my DHCP server and sometimes all clients getting issues of not getting IP address and when I check the show ip dhcp-conflicts, it shows there will be plenty of gratuitous APR request entry associated to an IP address and a mac address. Due to which the dhcp scope is  fully utilized. When I clear ip dhp conflict* , things will be normal. How to prevent it.
Cleetus
2 Accepted Solutions
a.alekseev
Level 11
Level 11
no ip dhcp conflict logging
balaji.bandi
Can you post some output when the problem exists :
show ip dhcp conflict
show ip dhcp pool
How many devices  in the network for that pool, make sure you have enough IP in that range.
BB
BB
as mentioned in my post, "show ip dhcp conflict" shows many lines of Gratuitous ARP entry with mac address and Ip address.
"show ip dhcp pool "  shows 0.0.0.0 as current index. which means there is no more address left for clients. So I clear the dhcp conflicts and thus I get enough addresses.
