GRE routing and encryption on ASR1000 platforms
Hello everyone, I have a routing issue involving GRE Tunnels, traffic routing across them and future encryption for that traffic.  Currently I have 2 ASR1002 routers that are connected via gigabitethernet ports traversing a metro ethernet.  The connection is full functional and traffic is flowing, however I have a requirement to both segregate the traffic across (GRE TUNNEL) the link and eventually encrypt that traffic to prevent outside access or interception.  I have included partial exceprts of the configurations:
Router inside main faciity
interface Tunnel200
description Metro Tunnel B9 to Townsite
ip address x.x.x.6 255.255.255.252
keepalive 10 3
tunnel source GigabitEthernet0/1/0
tunnel destination x.x.x.197
interface GigabitEthernet0/0/0    --Port into core--
ip address x.x.x.193 255.255.255.252
ip policy route-map Metro_Link
negotiation auto
interface GigabitEthernet0/1/0     --Port into metro ethernet--
description B9 - Townsite
ip address x.x.x.198 255.255.255.252
no negotiation auto
router eigrp 1515     --Main eigrp AS
network x.x.x.x
no eigrp log-neighbor-changes
router eigrp 200        --EIGRP AS for Tunnel
network x.x.x.4 0.0.0.3
passive-interface default
no passive-interface Tunnel200
access-list 199 permit ip any x.x.xx2.0 0.0.0.255
access-list 199 permit ip any x.x.xx3.0 0.0.0.255
access-list 199 permit ip any x.x.xx.4.0 0.0.0.255
access-list 199 permit ip any host x.x.x.191
access-list 199 permit ip any x.x.x.200 0.0.0.3
route-map Metro_Link permit 10
match ip address 199
set interface Tunnel200
This was set up to force all traffic entering this router to the distant subnets to use the GRE Tunnel.
The distant end router is to use the Tunnel for all traffic other that the local subnets
interface Tunnel200
ip address x.x.x.5 255.255.255.252
keepalive 10 3
tunnel destination x.x.x.198
ip address x.x.x.202 255.255.255.252
no negotiation auto
ip address x.x.x.197 255.255.255.252
no negotiation auto
router eigrp 1515
network x.x.x.x
router eigrp 200
ip route 0.0.0.0 0.0.0.0 Tunnel200                 --Default route
ip route x.x.xx2.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route x.x.xx3.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route x.x.xx4.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route x.x.x.191 255.255.255.255 GigabitEthernet0/0/0     --subnet on attached switch
access-list 199 permit ip x.x.xx2.0 0.0.0.255 any
access-list 199 permit ip x.x.xx3.0 0.0.0.255 any
access-list 199 permit ip x.x.xx4.0 0.0.0.255 any
access-list 199 permit ip host x.x.x.191 any
access-list 199 permit ip x.x.x.200 0.0.0.3 any
Both ASR1002 routers have identical IOS versions, ESP10 and SPA cards 5x1Ge
Links are G0/0/0 to either core or area switch and G0/1/0 to metro ethernet.  Tunnel with future encryption needs to be on the second link.
All traffic flowing in either direction needs to be encrypted as the metro link is provided by an external agency.
What is the best approach to accomplish this?  Sample configurations would be greatly appreciated as I have tried IPSEC tunnel alone and no traffic was being encrypted.
Richard Burts
Michael
If you tried the IPSec tunnel and no traffic was being encrypted then there was a flaw in your implementation. Either the IPSec configuration was flawed or the routing logic to send traffic through the tunnel was flawed.
I have read through your post several times and still do not have a clear understanding of what is going on. In particular the profusion of x.x.x in the addressing makes it very difficult to understand what is going on. If you do not want to expose your addressing (which is understandable) then perhaps you can transpose your addressing to the appropriate private addressing range (10.0.0.0 if your network is class A, or 172.16.0.0 is your network is class B, or 192.168.0.0 if your network is class C) and give us addresses that help us see what addressing is on the tunnels, what is on the interfaces, etc.
Rick
Rick
Richard Burts
Michael
Rick
Rick
Rick here is the modification.  I actually mispoke on the encryption I did in fact see sa's and a few packets encrypted and decrypted, however I lost connectivity to all the user subnets.  I will added the configuration I used for that at the end.
interface Tunnel200
ip address 172.16.0.6 255.255.255.252
keepalive 10 3
tunnel destination 10.0.0.197
ip address 10.0.0.193 255.255.255.252
negotiation auto
ip address10.0.0.198 255.255.255.252
no negotiation auto
network 10.0.0.0
network 172.16.0.4 0.0.0.3
access-list 199 permit ip any10.0.0.2.0 0.0.0.255
access-list 199 permit ip any 10.0.3.0 0.0.0.255
access-list 199 permit ip any 10.0..4.0 0.0.0.255
access-list 199 permit ip any host 10.0.0.191
access-list 199 permit ip any 10.0.0.200 0.0.0.3
interface Tunnel200
ip address 172.16.0.5 255.255.255.252
keepalive 10 3
tunnel destination 10.0.0.198
ip address 10.0.0.202 255.255.255.252
no negotiation auto
ip address 10.0.0.197 255.255.255.252
no negotiation auto
router eigrp 1515
network 10.0.0.0
router eigrp 200
ip route 10.0.2.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route 10.0.3.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route 10.0.4.0 255.255.255.0 GigabitEthernet0/0/0     --subnet on attached switch
ip route 10.0.0.191 255.255.255.255 GigabitEthernet0/0/0     --subnet on attached switch
access-list 199 permit ip 10.0.2.0 0.0.0.255 any
access-list 199 permit ip 10.0.3.0 0.0.0.255 any
access-list 199 permit ip 10.0.4.0 0.0.0.255 any
access-list 199 permit ip host 10.0.0.191 any
access-list 199 permit ip 10.0.0.200 0.0.0.3 any
This was the format I had used for the IPSEC
Townsite
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key Help address 0.0.0.0 0.0.0.0
crypto IPsec transform-set Metro_Link esp-3des esp-sha-hmac
crypto IPsec profile Hello
set transform-set Metro_Link
int tunn 200
desc Metro Tunnel B9 to Townsite
ip 172.16.0.5 255.255.255.252
tunn sour 10.0.0.197
tunn dest 10.0.0.198
tunn mode IPsec ipv4
tunn protec IPsec profile Hello
B9 ASR config statements
encr 3des
group 2
int tunn 200
ip 172.16.0.6 255.255.255.252
tunn sour 10.0.0.198
tunn dest 10.0.0.197
ip route 10.0.2.0 255.255.255.0 Tunnel200
ip route 10.0.3.0 255.255.255.0 Tunnel200
ip route 10.0.4.0 255.255.255.0 Tunnel200
ip route 10.0.0.200 255.255.255.252 Tunnel200
Interesting one....my guess is it might have something to do with "order of processing".....where policy maps are last to looked at when a packet enters a routers interface...may want to try it without policy maps.....see below:
3. Network Based Application
Recognition (NBAR)
4. BGP Policy Accounting
5. Output QoS Classification
6. Output ACL Check
7. IOS IPS Inspection
8. Input Stateful Packet Inspection (IOS FW)
9. Input ACL
10. Input Flexible Packet Matching (FPM)
11. IPsec Decryption ( if encrypted)
12. Unicast RPF Check
13. Input QoS Marking
14. Input Policing (CAR)
15. Input MAC/Precedence Accounting
16. NAT Outside-to-Inside
17. Policy Routing
1. IP Traffic Export (RITE)
2. QoS Policy Propagation thru BGP ( QPPB)
somehow the 1 and 2 got out of place when I pasted the order of processing.....
