GRE tunnel
jonk34567
Level 4
Level 4
image is attached below. i have configured a tunnel between R1 and R2.if i need to configure a static route on R1 what is the correct command
   R1# ip route 2.2.2.2    255.255.255.255   10.1.1.1
        or
        10.1.1.2
Local tunnel ID.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Seb Rupik
ip route 2.2.2.2 255.255.255.255 10.1.1.2
Since it doesn't look like you are running a dynamic IGP between the routers you will probably need to install the opposite route in R2:
ip route 1.1.1.1 255.255.255.255 10.1.1.1
cheers,
Seb.
As Seb mentioned, or you can set up
Router 1
ip route 2.2.2.2 255.255.255.255 tunnel <tunnel ID>  <--- Local Tunnel
Router 2
ip route 1.1.1.1 255.255.255.255 tunnel <tunnel ID>  <--- Local Tunnel
is it local tunnel id or opposite tunnel id
Local tunnel ID.
