Inter-vlan routing not working on the C3750X Layer 3 Switch. Help!!!
elom.kutsienyo
Hi all,
Just configured a 3750x switch as a DHCP server for some vlans and even though the ip routing is enabled, I am unable to route between vlans.
Note that the 3750x serves as a core switch that connects through trunking to 2960s accesss switches. VTP v3 is enabled, as well as VTP pruning, all SVIs configured. DHCP gives the respective SVI as gateway for the PCs. The computers connect through IP phones so the ports on the 2960S are on multi-vlan access mode.
I am wondering why I am unable to route between my vlans as I can see all subnets on respective SVIs in the routing table of the switch. I also used the default gateway comand on the 2960S switches so they are able to ping all the SVIs but the PCs on the access ports are not able to do the same and possibly exchange information with each other on different networks.
Thanks in advance for your help.
Igor
Have you run the debug ip icmp command on the 3750-X, as per Karsten's suggestion yesterday? Depending upon the situation, it might be best to ensure that you only send output to your log, not the command line interface. Setup the debug and then jump onto one of the clients and run a ping to an SVI on the 3750-X. If the 3750-X receives the ICMP requests, then you'll see them in the log (one for each echo request.)
Testing the other way can be done by running wireshark on a client. Then jump onto the 3750-X and source a Ping from another network (either the VLAN ID or SVI IP address): -
ping x.x.x.x source vlan xx
ping x.x.x.x source x.x.x.x
I would also connect a client machine directly to the switch, in case the problem is related to the IP phones. Amend the switchport config accordingly.
30 Replies 30
Can you reach the default-gateway address from the PCs?
If not, are all needed VLANs allowed on the trunk? Are the VLANs really availabe on the Access-switch (or is VTP really working)?
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Thanks for your answer,
Yes the PCs are able to ping their respective default gateways.
for now all VLANs are allowed on the trunk, as I am receiving all of them through VTP v3 on the access switches.
The access switches are able to ping all SVIs but the devices connected to them are not. Only their default gateways.
If you run a "debug ip icmp" on the 3750X and ping a IP of the switch that is not the DG of the PC (pinging from the PC), do you see any output?
do traceroute from PC to IP. does this reach your default gateway?
No please, the traceroute dies at the default gateway.
When I ping my default Gateway I see the debuging packcets but when I ping an external network, nothing shows.
Have you double-checked the IP-settings that the PC learns? Escpecially that there is no typo in the Default-Gateway?
There is also no output if you ping 192.168.10.254 from the PC?
Can you share route print from PC ? I am suspecting subnet mask configured on your system
I know you can ping the local default gateway from each client machine, but has DHCP correctly learned a default gateway address?
Any ACLs configured?
Any permenant routes configured on the client machines that might be preferred over the DHCP-learned default route?
I have not configured any route yet, nor any access lists. I just uploaded the configuration on the core switch to the discussion. If anyone spot an error, I will be so pleased.
elom.kutsienyo
The configuration is as follow:
Current configuration : 5284 bytes
! Last configuration change at 00:50:41 UTC Mon Mar 1 1993
version 12.2
no service pad
service password-encryption
hostname xxxx
boot-start-marker
boot-end-marker
username admin privilege 15 password 7 xxxx
no aaa new-model
switch 1 provision ws-c3750x-24
system mtu routing 1500
ip routing
ip dhcp excluded-address 192.168.30.1 192.168.30.50
ip dhcp excluded-address 192.168.30.254
ip dhcp excluded-address 192.168.40.1 192.168.40.50
ip dhcp excluded-address 192.168.40.254
ip dhcp pool DATA
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.254
   domain-name xxxx
   dns-server 4.2.2.2
ip dhcp pool PHONE
   network 192.168.40.0 255.255.255.0
   default-router 192.168.40.254
   domain-name xxxx
   dns-server 4.2.2.2
ip domain-name xxxx
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
interface GigabitEthernet1/0/1
description ### CONNECTIONS TO SERVER LAN PORTS ###
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
description ### CONNECTION TO STORAGE AND SERVER iSCSI PORTS ###
switchport access vlan 20
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
description ### DOWNLINK TO ACCESS SWITCHES ###
switchport mode trunk
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description ### UPLINK TO INTERNET ROUTER ###
switchport access vlan 90
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
interface Vlan10
description ### FOR SERVER LAN DATA TRAFFIC ###
ip address 192.168.10.254 255.255.255.0
interface Vlan20
description ### FOR iSCSI SAN TRAFFIC COMMUNICATIONS ###
ip address 192.168.20.254 255.255.255.0
interface Vlan30
description ### FOR END-USER WIRED LAN TRAFFIC ###
ip address 192.168.30.254 255.255.255.0
interface Vlan40
description ### FOR IP TELEPHONY TRAFFIC ###
ip address 192.168.40.254 255.255.255.0
interface Vlan50
description ### FOR DMZ SERVER TRAFFIC ###
ip address 192.168.50.254 255.255.255.0
interface Vlan60
description ### FOR IN-BAND MANAGEMENT TRAFFIC ###
ip address 192.168.60.254 255.255.255.0
interface Vlan90
description ### UPLINK FROM CORE SWITCH TO INTERNET ROUTER ###
ip address 192.168.90.254 255.255.255.0
ip http server
ip http secure-server
logging esm config
line con 0
logging synchronous
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
The problem is that you have configured the same ip of the gateway X.X.X.254 for the management of the router. Each VLAN has its own management IP and it has to be different from the gateway of the same VLAN
ip dhcp pool DATA
    default-router 192.168.30.254 ---> Gateway
    domain-name xxxx
    dns-server 4.2.2.2
Vlan30 interface
ip address 192.168.30.254 255.255.255.0 -> Management IP
When you ping 192.168.30.254 from a VLAN 30 PC, you are reaching the management IP, not the gateway. Surely if you put 192.168.30.254 in a web browser by http you enter the configuration mode of the 3750
elom.kutsienyo
I am begining to wonder if there is not a default command somewhere that needs to be changed or soemthing of that sort that is specific to 3750x switches.
