GUI for configuring Cisco-831 router
axfalk
Can someone please point me to where I can download the GUI for configuring Cisco-831 router?
Thanks.
try this link, you need a CCO logon to actually download the software:
Software Download
Cisco Security Device Manager
http://www.cisco.com/pcgi-bin/tablebuild.pl/sdm
HTH,
GP
Thanks, it helped. I have inherited this router and need to tweak it a bit.The config has ethernet0 interface configured, among other interfaces, even though the router does not have a physical port for it. When I do "sh int eth0", it's down down, so i can't quite figure out its purpose. Anybody happened to know if this is some kind of virtual port on the 831 routers?
Thanks again.
Thanks.
the 831 has a built-in four-port switch, the Ethernet0 interface is indeed a virtual interface which serves as the default gateway for the hosts connected to the four switchports. You need to configure this interface with an IP address just like a ´real´ physical interface.
HTH,
GP
