GUI for Router
batumibatumi
Dear Friends,
I have 881 series routers and i wanna to use SDM  or something like this web based software, I tried CCP but it has lot's of bugs. Could you please advice me what i should to do ?
I just want to configure VPN using web interfaces.
Thank you in advance!
Krishnendu AR
Please enable and http and https service in the router. After you can access the device through its GUI. Issue the below commands from the configuration mode:
ip http server
ip http authentication local
ip http secure-server
Make sure that you have a local user name and password configured.
Router(config)#ip http ?
  access-class                   Restrict http server access by access-class
  accounting                     Set http server accounting parameters
  active-session-modules         Set up active http server session modules
  authentication                 Set http server authentication method
  client                         Set http client parameters
  digest                         Set http digest parameters
  help-path                      HTML help root URL
  max-connections                Set maximum number of concurrent http server connections
  path                           Set base path for HTML
  port                           Set http port
  secure-active-session-modules  Set up active http secure server session modules
  secure-ciphersuite             Set http secure server ciphersuite
  secure-client-auth             Set http secure server with client authentication
  secure-port                    Set http secure server port number for listening
  secure-server                  Enable HTTP secure server
  secure-trustpoint              Set http secure server certificate trustpoint
  server                         Enable http server
  session-module-list            Set up a http(s) server session module list
  timeout-policy                 Set http server time-out policy parameters
If you want, you can even setup up access-list restricting the inbound http/https access from specific IPs only.
Krishna
