GUI Web Interface Gone
Silly question but I just updated my Cisco 891-W's wireless access point to the latest and greatest version. Now when I log onto the AP via HTTP, I get the generic screen like so..
Cisco Systems
Accessing Cisco AP801AGN-A-K9 "TTCAP02"
I can see on the flash: directory under the IOS directory ap801-k9w7-mx.152-2.JB that there is the html directory and underneath that the level/15 directories with all the files in it so I am confident that the IOS upgrade went well but how do I get the web gui back? I tried the "http path" and that did not work. I compared it to another access point and the paths are the same with the exception of the IOS directories, which is to be expected.
So I am officially stumped now and would greatly appreciate any help on the matter as this is driving me crazy.
Charles
8 Replies 8
jawad-mukhtar
Level 10
Level 10
Have you taken backup of your OLD IOS.
Jawad
While that would have been the smart thing to do, no I did not.
Do you have access to console
Jawad
Yes. The AP is still working and I can SSH into it.
Charles
Do access AP via https
Jawad
Same thing
Cisco Systems
OK. Got it working by flashing a different version (ap801-k9w7-tar.152-2.JA1) to it and following the post at
https://supportforums.cisco.com/docs/DOC-13047
It looks like the version that I had on it, ap801-k9w7-tar.152-2.JB has a bug.
Thanks for the assistance.
Charles
Charles
I am struggling to find any AP801 code that is autonomous  I think W7 in the code name
there is a bug in 124-21a.JA1 that breaks PPTP
and I wonder if you have a link to 12.4(21a)Y or newer as the bug is fixed
But searching all over the support downloads I cannot find any W7 versions  (Stand alone)
only W8 which is LWAPP
thank you in advance
steve
