Access List Help
Egor Khomenko
Level 3
Level 3
Hi! I want to set acces sheets. There is a network:
  10.30.6.0 with a mask of 255.255.255.0, it is necessary that she went to the Internet on port 80 and 443, and the other ports are closed
10.30.7.0 with a mask of 255.255.255.0 went to the Internet for 80, and went over the network to address 10.50.51.250, and the rest are closed
10.30.9.0 had full access
Help set up ACL!???
daniel.dib
Level 11
Level 11
conf t
ip access-list extended NETWORK_6
permit tcp 10.30.6.0 0.0.0.255 any eq 80
permit tcp 10.30.6.0 0.0.0.255 any eq 443
deny ip any any
ip access-list extended NETWORK_7
permit tcp 10.30.7.0 0.0.0.255 any eq 80
permit ip 10.30.7.0 0.0.0.255 host 10.50.51.250
deny ip any any
ip access-list extended NETWORK_9
permit ip any any
However if you only open for 80 and 443, how do you handle DNS?
Also you have to think about return traffic if you want to do filtering.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
5 Replies 5
daniel.dib
Level 11
Level 11
conf t
deny ip any any
deny ip any any
permit ip any any
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
You don't need the deny ip any any at the end because the ACL has an explicit deny at the end of it.
I know but I usually add it there for clarity.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Apply to the interface as a group?
and yet, as you can on this Vlan prisvoit.T.e. DHCP is set to distribute the network??
Thank you so much! I helped your article!
