11-22-2017 11:10 PM - edited 03-08-2019 12:51 PM
Hi.
We have a monitoring tool. We are constantly faced with such an error 3750x switch
"Hardware Sensor Name : Sw1, PS1 Faulty, RPS NotExist. Category : power. Current State : notFunctioning(6) - The sensor is operating under critical or fatal conditions. This may directly affect the functioning of both the sensor and related components."
what is the source of this problem?
11-23-2017 12:09 AM
- Could be harmless, if all power supplies are OK. Check using show env all ; possibly upgrade to a gold-starred release, if current version is below such trains. Check if message persist afterwards.
M.
11-23-2017 02:57 AM
Everythink seeing is a normal
#show env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 27 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-350WAC XXXXXXXXXX OK Good Good 350/0
1B C3KX-PWR-350WAC XXXXXXXXXX OK Good Good 350/0
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
11-23-2017 04:33 AM
- Since the RPS (port) is not used; the message is probably bogus
M.
11-23-2017 06:39 AM
Yes it looks like it is probably this bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCui31295/?referring_site=bugquickviewredir
