IE-1000-8P2S-LM
Does IE-1000-8P2S-LM switch with PWR-IE170W-PC-AC= each port support between 7 & 13 watt ?
Jeswin Samuel
As per datasheet , switch IE-1000-8P2S-LM supports 8 ports PoE/PoE+,
PWR-IE170W-PC  supports  , Support up to 8 ports PoE or 5 PoE+ ports  ,
So yes all supports minimum PoE (15.4w)
Hope this helps,
