Having issue with directly connecting to CISCO switch using putty
amit.malik
Hi All,
            I am having issue with directly connecting to the CISCO 2960 switch from Putty. I am only able to connect to these switch by connecting to router in my organization first and than to switch using ssh  -l company IP-address command.
When i am connecting direct to the Switch using Putty its rejecting my connection
here is the basic configuration of switch -
no service pad
service password-encryption
hostname testswitch
boot-start-marker
boot-end-marker
enable secret ******
username test secret *********
no aaa new-model
vtp domain company.com
vtp mode transparent
ip domain-name company.com
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 11
 name ****
vlan 14
 name *****
vlan 15
 name Guest
vlan 16
 name management
ip ssh version 2
interface Vlan1
 no ip address
interface vlan16
 ip address ****
 ip helper-address  ****
ip default-gateway
no ip http server
no ip http secure-server
ip access-list extended remoteaccess
 permit ip *** **** any
banner login ^CCCC
^C
line con 0
 exec-timeout 30 0
 login local
line vty 0 4
 exec-timeout 15 0
 login local
 transport input ssh
line vty 5 15
 login
ntp server ***
end
Now problem is that router is being managed by vendor. But switches are still managed by us.
I can't log on the switch using putty until I first log onto the router and than ssh from there.
I am not very experienced in CISCO switching. This is my first post to this forum :)
Is there any way i can directly connect to switch using Putty?
mamdohmardini
Hi Amit,
I think you are not able to see the management ip of the switch because the ip address is not reachable in your network, please try to do traceroute inside your network and find out at which node the trace stops. At this node add a specific route for the mgmt ip of your switch pointing to the next hop.
BR
MTM
mamdohmardini
Hi Amit,
BR
MTM
Thanks mamdohmardini issue was with wrong default-gateway.
