having problem with cisco cwdm sfp
Tony Cheng
i'm testing the cisco CWDM between 2 switches, the issue is if i fully insert the LC connector on both end of the cwdm sfp then it won't work, but if i have one side fully inserted the LC typed fiber to the cwdm sfp, while leaving the the other end not fully inserted into the cwdm sfp then the interface will come up, why is that ?
Tony Cheng
below is a good case, if i left one end of the fiber LC connector losely inserted into the CWDM SFP, when the interface are up/up on both ends of the switches over CWDM SFP:
Test-SW01#
Test-SW01#sh int trans module 1
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Gi1/1/1      39.2       3.29       2.8      -8.0
Gi1/1/4      39.3       3.30       2.2      -9.0
Test-SW01#
below is bad case, when interface are down/'down, when i inserted both ends fully into the cwdm sfp:
below is bad case, that interface won't come up.
                                 Optical   Optical
Gi1/1/1      38.2       3.55 +     8.1 +   -40.0
Gi1/1/4      39.3       3.30       2.1      -9.1
quesiton is , is there any parameter i can configure on the switch to make the RX power from -40 to -8 ?
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You might want to move this question to the Optical Networking forum.  (My guess would be you might need an attenuator.)
