Setting up DHCP snooping?
abrrymnvette
I'm going to setup DHCP snooping and had a question about it.
My DHCP server is connected to port 1 on a switch stack. I set that port as "ip dhcp snooping trust"
The trunk link that connects my switches together also gets set as "ip dhcp snooping trust"
Do I have to do anything on my switch stack at the other end of the trunk line? The VLAN's already have the ip-helper address configured.
DHCP server ----------Switch Stack 1<><><><>Switch Stack2---------DHCP Client
Basically, I think this is all I need to do:
Switch1(config)#ip dhcp snooping
Switch1(config)#ip dhcp snooping vlan 10
Change to the trunk interface:
Switch1(config-if)#ip dhcp snooping trust
Change to the interface connected to my DHCP Windows server:
Change to Switch2 and configure the trunk port that connects to Switch1 as trusted?
Switch2(config-if)#ip dhcp snooping trust
hello
you seem to have got it!
just make sure is snooping enabled on all
switches between dhcp server and clients
and you seem to have done that
res
paul
Kind Regards
Paul
johnd2310
Level 8
Level 8
Just to add to what has been said, you also need the following commands on all the switches:
ip dhcp snooping
regards
John
**Please rate posts you find helpful**
