08-06-2019 02:21 AM - edited 08-07-2019 05:54 PM
Hello Guys,
Would u help me any tip or wise mention further detail config is better.
I wondering, Ingress Traffic handling is possible for 2960s ?
I just want to limit E/Ingress Traffic Bandwidth limit.
current config is below,
mls qos
access-list 199 permit ip any any
class-map match-all 150m
match access-group 199
policy-map 150-limit
class 150m
police 150000000 500000 exceed-action drop (don't know exactly calculate Bursting size, so I just took it as big as 500000)
interface GigabitEthernet1/0/31
srr-queue bandwidth limit 20 ( it works for egress I know)
service-policy input 150-limit
Egress is good, but can't handling Ingress.
I don't care CoS or any Priority, just limit bandwidth just as 150Mbps or 250Mbps like some.
below is iperf3 result
[ 5] 0.00-1.00 sec 2.27 MBytes 19.0 Mbits/sec
[ 5] 1.00-2.00 sec 2.82 MBytes 23.6 Mbits/sec
[ 5] 2.00-3.00 sec 2.28 MBytes 19.1 Mbits/sec
[ 5] 3.00-4.00 sec 2.22 MBytes 18.6 Mbits/sec
[ 5] 4.00-5.00 sec 2.15 MBytes 18.0 Mbits/sec
[ 5] 5.00-6.00 sec 2.19 MBytes 18.4 Mbits/sec
[ 5] 6.00-7.00 sec 2.18 MBytes 18.3 Mbits/sec
[ 5] 7.00-8.00 sec 2.17 MBytes 18.2 Mbits/sec
[ 5] 8.00-9.00 sec 2.22 MBytes 18.6 Mbits/sec
[ 5] 9.00-10.00 sec 2.36 MBytes 19.8 Mbits/sec
[ 5] 10.00-10.04 sec 0.00 Bytes 0.00 bits/sec
ISO is
C2960S-UNIVERSALK9-M, Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
Someone help me ?
Thanks in advance u guys assistance in this matter
Solved! Go to Solution.
08-06-2019 05:45 PM - edited 08-06-2019 07:04 PM
Hello Dave, Thank you for your reply,
Dave, you didn't mean both of numbers divide by 8 for byte ? did u ?
So, It is
police 150000000 18750000 exceed-action drop
for the ingress for 150mbps. (I want to)
hm,,, some wired,
on 2960s
Burst size max is 1000000
below is my 2960s CLI
7F_SW3(config-pmap-c)#police 150000000 ?
<8000-1000000> Normal burst bytes
Guess it gonna be mystery some.
Thank you
any further info plz ?
08-07-2019 12:35 AM
Checking the command reference for the 2960S I see:
police rate-bps burst-byte [ exceed-action { drop | policed-dscp-transmit }]
Where:
rate-bps | Specify the average traffic rate in bits per second (b/s). The range is 1000000 to 1000000000. |
burst-byte | Specify the normal burst size in bytes. The range is 8000 to 1000000. |
So your command would be:
police 150000000 1000000 exceed-action drop
This will give you a sampling interval of around 50ms (8 x 1M/150M), which should be OK. To get a longer sampling interval you would have to use a router.
Hope this helps,
Dave
08-06-2019 07:20 AM
Caveat - I have not done this on a 2960S.
In a lot of cases policing is listed in units of bytes per second, not bits - hence you need to divide your numbers by 8. This is as opposed to shaping that is usually in bits. I tend to remember it as "Police dog Bites".
Hope this helps,
Dave
So, It is
hm,,, some wired,
on 2960s
Thank you
08-07-2019 12:35 AM
Where:
Hope this helps,
Dave
08-07-2019 01:58 AM - edited 08-07-2019 01:59 AM
Thx for the reply Dave, But it Wouldn't work (but I select your answer)
just burst size different between you and me.
By the way,
It looks broken,
the traffic already changed into narrow size than before when I put the 'mls qos' in global mode without any config.
08-07-2019 01:38 AM - edited 08-07-2019 01:42 AM
Hello
My understanding for a router the Bc value for policing is calculated as below but obviously the switch is a bit different
CIR/32
or
CIR/0.25/8
So 150MB CIR
BC= 150MB/32
150000000/32 =4687500
08-07-2019 02:01 AM - edited 08-07-2019 02:10 AM
Hello Paul,
Yes quite a bit diff.
traffic *1.5/8 = xxx bytes is bc on switch.
Btw, thank you for the reply Paul.
