ā12-06-2011 07:27 AM - edited ā03-07-2019 03:46 AM
Can you please help with the following
we are adding few Powerconnect 8024F Dell switch on our Network.
The problem we have is we are running RSTP on Dell switches and are using RSTP PVST on cisco 3750 stacks that directly connects to the del switches when we connect the two using trunk ports ideally it should recognise the cisco switch as the root as it has lower spanning tree priority.
What we see on the DEL switch is
Regional Root Path Cost: 0
ROOT ID
Priority 32768
Address 5C26.0AD3.8D06
This Switch is the Root.
Hello Time 2 Sec Max Age 20 sec Forward Delay 15 sec TxHoldCount 6
What we see on the cisco switch is
KB-SR1-6509-1#sh spanning-tree vlan 185
VLAN0185
Spanning tree enabled protocol rstp
Root ID Priority 8192
Address 0011.bc7c.08b9
Cost 3
Port 1669 (Port-channel10)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 16384
Address 0011.bc6b.d0b9
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Po8 Desg FWD 3 128.1667 P2p
Po10 Root FWD 3 128.1669 P2p
Po12 Desg FWD 3 128.1671 P2p
Vlan 185 exist both on the Del switch and cisco switch and is allowed over the trunk ports adn as you can see we have two Root bridge switches fro the same vlan (we only have a single link connected to the DELL switch)
Is there a risk with the above setup
Kind Regards,
Zeeshan Siddiqui
ā12-06-2011 08:12 AM
Is
the MAC of the DELL switch?
Rais.
ā12-06-2011 09:02 AM
It is the mac address of the cisco switch (6509 HSRP pair)
A diagram would be
6509-1 ----------HSRP---------- 6509-2 (6509-1 has uplinks to 3750 stack 1 and uplinks to 3750 Stack2)
+ > < + (6509-2has uplinks to 3750 stack 1 and uplinks to 3750 Stack2)
3750 stack 1 3750 Stack 2
DEL switch (connect to 3750 by a trunk port) vlan allowed on trunk is 185 ) .
Below is output for Sh spanning tree on DEL switch (does not support RAPID PVST)
ROOT ID
Priority 32768
Below is out put on 6509 (avtive member for 6509 HSRP pair on vlan 185) running rapid PVST
Please see output below
VLAN0185
This bridge is the root
Bridge ID Priority 8192
Aging Time 300
Po10 Desg FWD 3 128.1665 P2p
Po12 Desg FWD 3 128.1667 P2p
Po8 Desg FWD 3 128.1672 P2p
Both switches can see each other over the trunks
ā12-06-2011 09:57 AM
Is it correct that VLAN 185 is defined on 3750 stack 1 in VLAN database?
Thanks.
ā12-07-2011 04:03 AM
Hi rais,
Thanks for your reply
Vlan does exist on the VLAN database. (the 3750 is acting as a layer two switch) in one VTP domain as a VTP client.
The DEL switch is not part of the VTP domain stand alone switch.
Kind Regards,
Zee
ā12-07-2011 04:57 AM
Well, bpdu's are basically the heart of spanning tree, so maybe they're having issues reading each other bpdus?
What do the port states look like on the trunk connecting the Dell Switch to the 3750.
ā12-07-2011 05:02 AM
We have allowed another vlan over the trunk ports for testing which is 184
KB-SR3-3750-2#sh spanning-tree int Gi2/0/8
Vlan Role Sts Cost Prio.Nbr Type
VLAN0184 Desg FWD 4 128.60 P2p
VLAN0185 Desg FWD 4 128.60 P2p
KB-SR3-3750-2#
KB-SR3-3750-2#
KB-SR3-3750-2#
There is only one link to the DEL switch
ā12-07-2011 05:00 AM
According to the outputs you attached the Dell switch is running MSTP and not RSTP.
Regional Root Path Cost: 0 <<<
Regions are paramters used in MSTP.
According to Dell datasheets this powerconnect supports 3 flavors of STP.
IEEE 802.1D ā Spanning Tree1
IEEE 802.1S ā Multiple Spanning Tree
IEEE 802.1W ā Rapid Spanning Tree1
http://www.dell.com/us/enterprise/p/powerconnect-8024f/pd
You should check one of the Dell/Cisco STP interoperation guide available on the Internet to get an idea of what to do.
If your 3750 is running RSTP but does not have vlan 185 it is expected that you have more than one root bridge.
I suggest you to change the STP flavor on your Dell box first since apparently you have the option to do that.
Riccardo
ā12-07-2011 05:17 AM
DELL switch below
console#show spanning-tree summary
Spanning Tree Adminmode........... Enabled
Spanning Tree Version............. IEEE 802.1w
BPDU Guard Mode................... Disabled
BPDU Flood Mode................... Disabled
BPDU Filter Mode.................. Disabled
Configuration Name................ 5C-26-0A-D3-8D-06
Configuration Revision Level...... 0
Configuration Digest Key.......... 0xac36177f50283cd4b83821d8ab26de62
Configuration Format Selector.....
For 3750 below
spanning-tree mode rapid-pvst
spanning-tree loopguard default
no spanning-tree optimize bpdu transmission
VLAN0185
Address 0011.bc7c.08b9 (MAC for 6509)
Cost 3
Port 704 (Port-channel12)
Bridge ID Priority 32953 (priority 32768 sys-id-ext 185)
Address 0012.43ba.9680
Aging Time 300
Po11 Altn BLK 3 128.696 P2p
Po12 Root FWD 3 128.704 P2p (port-channel that connects to 6509)
Gi2/0/8 Desg FWD 4 128.60 P2p
Dell are investigating the problem at there end and plan to migrate the DEL switches from RSTP to MST.
Any know problems when we use Rapid PVST and MST ?
ā12-07-2011 05:21 AM
Well, if you do that you are going to have separate spanning-tree domains so to speak. You could end up having two root switches for the same vlan. The RPVST will have one and the MST will.
ā12-07-2011 05:28 AM
Some thing I dont undertsand
When I change the port from trunk to access on both switches (Cisco + DELL) it can see our switch as the root bridge when we change to trunk at both ends you have two root Switches?
ā12-07-2011 05:45 AM
This may sound like a stupid question, but when you set it to trunk, what vlans are allowed across the trunk?
ā12-07-2011 06:37 AM
They are allowed on the trunk port.
I can connect to the DEL switches over the trunk ports.
ā12-08-2011 07:15 AM
It almost sounds like when you change the port to access, both switches exchange bpdus, and are able to decide that the cisco switch is the root switch. But if you change it to trunk, bpdus are not exchanged and therefore you end up with separate root switches. Bug maybe, or they may not corporate with that cisco switch ???
ā12-08-2011 07:43 AM
Hi John
I complelety agree
the next step is we are goign to move the Dell switches to use MST as the DEll switch support MST (have done some testing using cisco switches one of them running rapid PVST and the other MST) we only had one root bridge and when we connected the second link it went to blocking.
The test I did was between cisco switch VS Cisco switch and not DEll vs Cisco (In theory the protocal should work the same)
