Help Changing 5510 ASA Interface IP
stle0
Dear All,
I am needing to change the internal IP scope for my network, however, when I make the change in my DCHP server I cannot change the Interface IP for my ASA 5510. Any ideas?
I have tried editing the Inside Interface Ethernet 0/1 AFTER the DHCP scope change and I lose communication along with several other errors. I have tried to edit the Inside Interface Ethernet 0/1 BEFORE the DHCP scope change and the same problems occur.
I have also tried disabling the Interface before making the change, however that didn't work either. I am guessing that there is a different area / way to change the IP for the Inside Interface Ethernet 0/1 than what I am doing.... any help would be greatly appreciated.
Thank you in advance!
Nagaraja Thanthry
I am assuming that you are using ASDM to access the firewall and making
changes in the ASDM. Please follow the steps below:
1> Through the ASDM, delete the DHCP scope on the firewall
2> Add the new IP range to the allowed addresses that can access ASDM
through HTTP (http 0 0 inside is a better option)
3> Now change the IP address on the inside interface
4> Configure a PC statically so that it has an IP in the same range as the
ASA's inside IP
5> Now access the ASA through the new IP from the statically configured PC
6> Now reconfigure the DHCP scope
Hope this helps.
NT
Nagaraja Thanthry
ASA's inside IP
Hope this helps.
NT
Ganesh Hariharan
Try to delete the interface and configure the interface once again in th below steps:-
ASA5510(config)# interface Vlan 1
ASA5510(config-if)# nameif inside
ASA5510(config-if)# security-level 100
ASA5510(config-if)# ip address 192.168.1.1 255.255.255.0
ASA5510(config-if)# no shut
Hope to Help !!
Ganesh.H
stle0
NT,
Thanks. That helped. I had to make a couple of other minor adjustments but that worked out great.
Mat
