HELP Cisco IE-4000 Power supply and POE
Daniel Griego
I am purchasing the IE-4000-8GT8GP Switch so i can power up to 8 POE devices. The switch has two DC power inputs that will take 12-54V DC. my question is:
Do i have to purchase one of the supported Cisco IE power supplies in order to support POE?, or can I use my own power supply? and what is the minimum DC voltage input rating I can use in order to support the use of POE?
seblind3r
BUMP! (if that's okay?).
I'm wondering the same thing.
I just got my hands on 2x IE4000 4S8P4G-E.
I am planning to use our current 24V 10A power supply.
Will I be able to use 8x PoE ports?
Or does the switch require 48V for PoE to function?
