Help! Cisco Newbie.
I am a small office IT guy just breaking into a new 3825....
I am trying to get it going with VLANs and a good solid config before implementing CME. I cannot seem to get any system connected to a VLAN assigned port (ex. VLAN 18 for PCs) as my laptop is now connected, to acquire DHCP or any connectivity.
The management vlan, or 1 is working fine, with all systems connected. Just all my other VLANs, so I assume its something rather simple. Our DHCP server is a Windows Server 2012, with a gigabit card, and I configured DHCP services with the VLANs appropriately. Even can ping the gateways from the servers (ex. 10.0.18.1) just fine. BTW the router is trunking directly to a TP-Link Web Smart 802.1q switch which has proper assigned ports and VLAN PVID set up ok.
Help!
Here is my current config (removed indentifying info):
USRMIHQ#sh conf
Using 3578 out of 491512 bytes
! Last configuration change at 20:12:42 EDT Tue Mar 12 2013
! NVRAM config last updated at 20:12:48 EDT Tue Mar 12 2013
version 15.1
hostname USRMIHQ
boot-start-marker
boot-end-marker
no logging console
enable secret 5 xxxxxx
enable password 7 xxxxx
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
dot11 syslog
ip source-route
ip cef
ip domain name usrangers.local
ip name-server 10.0.0.2
ip name-server 10.0.0.4
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-4021075919
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certifi
cate-40210
75919
revocation-check none
rsakeypair TP-self-signed-4021075919
crypto pki certificate chain TP-self-signed-4021075919
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
license udi pid CISCO3825 sn xxxxx
redundancy
interface GigabitEthernet0/0
description Internet Access
ip address 75.xxx.x.xx 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
no mop enabled
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.1
description Management Network
encapsulation dot1Q 1 native
ip address 10.0.0.1 255.255.255.0
ip helper-address 10.0.0.2
ip nat inside
interface GigabitEthernet0/1.16
description VOIP Network
encapsulation dot1Q 16
ip address 10.0.16.1 255.255.255.0
interface GigabitEthernet0/1.17
description Printer Network
encapsulation dot1Q 17
ip address 10.0.17.1 255.255.255.0
interface GigabitEthernet0/1.18
description PC/Client Network
encapsulation dot1Q 18
ip address 10.0.18.1 255.255.255.0
interface GigabitEthernet0/1.19
description IP Camera Network
encapsulation dot1Q 19
ip address 10.0.19.1 255.255.255.0
interface GigabitEthernet0/1.20
description Wifi Network
encapsulation dot1Q 20
ip address 10.0.20.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 75.xxx.x.xx
access-list 10 permit 10.0.0.0 0.0.0.255
snmp-server community public RO
control-plane
mgcp profile default
banner motd ^C
^C
line con 0
password 7 xxxxx
login
line aux 0
line vty 0 4
password 7 xxxxx
login
transport input all
scheduler allocate 20000 1000
ntp master
ntp server nist1-ny.ustiming.org
ntp server nist1-nj.ustiming.org
ntp server nist1-pa.ustiming.org
end
kcnajaf
Level 7
Level 7
Hi Frederick,
Which port on the router you have your switch connected to?
When you assign static ip address on the PC are you able to ping your gateway?
Najaf
kcnajaf
Level 7
Level 7
Hi Frederick,
Najaf
