help configuring NAT
fredluneau
I am having difficulties configuring NAT POOL for traffic on my internal network when hitting a specific interface to my firewall.  When traffic from a specific subnet (matching the ACL) goes to a specific interface (firewall VLAN) I need that traffic to NAT from pool.  Here is my config:
Router#(config)
ip nat pool Remote-Offices 10.168.0.0 10.168.255.255 prefix-length 16 type match-host
access-list 150 permit ip 192.168.168.0 0.0.3.255 any log
ip nat inside source list 150 pool Remote-Offices
Router#(config-if)
interface Vlan170
description Firewall Network
ip address 172.18.7.4 255.255.255.240
ip directed-broadcast
ip nat inside
end
With this config I do not see any nat translations when issuing a pingfrom a host on the 192.168.168.0/22  to a destination address on my firewall dmz which passes through VLAN170, which is also my static default route (172.18.7.1)
Any assistance would be most appreciated.  Thanks.
8 Replies 8
cadet alain
log keyword is not supported for NAT ACLs so just get rid of it.Also make sure your routing is correct because packets are routed first before being natted.
Alain
Hi Alain, Thanks for your reply.  I did remove the log keyword as suggested however that did not change the result.  Routing is functioning correctly as a traceroute I ran plots the expected path.
Any other thoughts?  Is there any additional detail I can provide which would help towards a solution?
Have you got a route back to this 192.168.168.0/22  on the  NAT device ?
Alain
Alain,
Sorry for the delay in responding.  Yes, routing for this subnet has and still is working normally.
Question....the svi interface, VLAN 170, should the configuration for NAT function as currently configured or do I need to change the switchports connecting the firewall to routed interfaces and put IPs on the gigabit interfaces?
Thanks.
-Fred
No you can leave it as is but where is the nat outside configured ? I don't see it in your config snippet and could you also post a quick diagram of your topology ?
Alain
Alain,
I have attached a diagram that should help explain better what we are attempting to do.
We have been internally discussing this this morning and re-reading the documentation and may have come up with a reason why we haven't been successful. Is it likely that we have been putting the ip nat inside statement on the wrong interface(s)?
I don't see the diagram so I can't tell you.
Alain
Alain, Sorry.  I had difficulties in getting the attachment in this duscussion.  Somehow the previous attachment I attempted went into a discussion area.  Anyway, I have attached the diagram into this discussion thread.  I am still hoping you can help.
Fred
