Help connecting into 2911 switch module
Clay Plaga
Level 5
Level 5
I have a cisco 2911 router with a switch module installed and configured. I am trying to connect to the switch module. I am using this command:
service-module gigabitethernet 0/0
Output is: Incomplete command
What is the full command to connect to the switch module?
Thank you.
Hello @Clay Plaga
Please refer here
-- https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html
To open a session from the router to the Cisco enhanced EtherSwitch service module
use the following command:
Router# service-module gigabitethernet0/0 session
Best regards
6 Replies 6
Mark Elsen
   - @Clay Plaga      Add a  ?           to the command to see available options
                              It could be service-module gigabitethernet 0/0 session
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I added the question mark, but it didn't like the session part.
Invalid input detected
Hello @Clay Plaga
Please refer here
Best regards
Yes, it was :
Router# service-module gigabitethernet1/0 session
On the 2911 router, that interface is labeled:
Gi0/0
Thank you.
I am using that command.
M02@rt37
@Clay Plaga
Do you assign IP add to Gi0/0 ?
Because it used reverse telnet to connect to the module...
Best regards
