Help in how to compare and choose the best?
ronaldo2010
hi all
how to select the best among types switches, routers ?
I would to select of the best between two type of switches and another two type routers .
- compare between switch cisco 1900 ,2940,2948
-compare between routers cisco 2501 and 2620
so please any help to support me by documents as PDF to make comparison .
12 Replies 12
Reza Sharifi
It all depends on your requirement.  For example: 2501 has a 10mb interface and 2620 has a 10/100 interface, but they are both end of life.
Is this for lab or for production?
How many user?
what type of connection?
What size network?
and most importantly, how much is the budget?
Reza
Leo Laohoo
There is no such thing as a one-size-fits-all when you are dealing with technology like this.  Question you should ask yourself is "What are you trying to acheive".  Another appropriate question is "What is your budget?".
ronaldo2010
Reza sharifi , leolaohoo
Thank you,I will explain to you in next reply
ronaldo2010
I am not a Specialist Network Engineering. And I try to collect sufficient information to make decision to in resolving the case study .
please see the attach file as sample JPG to understand the problem .
- (A) i have 6 workstations connected to with cable 100baseT with hub , there is a server connected with that hub with 100baseT
- (B) there is another 6 workstations connected to with cable 100baseT with hub .
- there is a router connected with first topology (A) with cable 100 baseT.
- and another router connected with second topology (B) with cable 100 baseT .
- both router connected together with T1 link .
The requirements : Change both hubs with switches , and i have two type of switches cisco (1900,2948) and i would to select one of them .
and also the same in routers i would to change it , i have two type routers cisco (2501,2620) and i would to select on of them .
If I get the specifications as PDF file I will select what is appropriate for me to case study
Kind Regards
Just want to let you know that both are end-of-sale/end-of-life.  The 2948G is CatOS while the 1900 is menu-driven.  Depending on the load of your PCs and if I have to make a choice (reluctantly), I'd go with the 2948G.
Good grief!  Where shop did you get your gear from????  I don't want to make a choice of either one.  The least-of-all-evil will have to be the 2620.
Leolaohoo
Thank you for your cooperation
I should have to choose between these only , (Router 2501or 2620 ) and ( switches 1900 or 2948g)
According to you and as i have searched in the web, I've concluded to solve case study to get the best in this case
Router 2620 and switch 2948g . in the begin i guess these it is better for me to solve the case study .
but i need to make sure here .
now how to get information( specification) for these Router 2620 and switch 2948g .
I will try my own to write report for what i select from these
but i need PDF file or any linke for cisco support information about Router 2620 and switch 2948g .
ronaldo2010
About budget does not matter
the important for me to provide any documents can support these cisco switches 1900,2948 and routers 2502,2620 to select one of them .
Overall i try to collect the information to improvement
As I noted before, 2600 and 2500 routers are end of life.
For this design, you can simply use 2 Cisco 2960 switches and 2 Cisco 2811 routers with proper WAN cards.
Here is the datasheet for 2960s:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
Reza
If budget does NOT matter, why bother collecting details of these obsolete equipment?
ronaldo2010
Leolaohoo
I will write Report but I need information to read it for specification to writer the reason why i select that .
just i need PDF file or any linke for cisco support information about Router 2620 and switch 2948g .
ronaldo2010
Reza Sharifi
Thank you
I know about these is end of life
but have to be i select from those .
just i would a link as this
the datasheet for router 2620 and switch 2948g
Sorry to hi-jack Leo and Reza, but this sounds like a project for school. Your efforts are better spent towards people that need help with production networks!
ronaldo2010: Google Cisco 2600 data sheet and you will find what you're looking for. Do the same for the other models.
