Showing results forĀ
Search instead forĀ
Did you mean:Ā
help in reducing cpu when using NAT & Policy map
Dr.X
Level 7
Level 7
hi , i would like to ask about using NA , im uisng Bras router with thousandes of users ,
i made a static nat for only one user  by #ip nat inside source xxxxx xxxx, and applied it to the interface router ,
the porblem occures that the cpu of the router  begins to exceed 90 % of usage !!!!!!!!!!!!
can i use another thing by reducing the trafffic ??
another issue ,
i alose use policy map  , does it gets alot of cpu usage ???
regads
Ton V Engelen
Level 7
Level 7
so, how many nat translations does this one user has?
I ve seen one user using 4000+ nat translations, which caused the cpu of a small router to go to 99%
show ip nat trans
show ip nat stats
that way you can see how many translations the user has.
If you want to restrict i
ip nat translation max-entries host
Like  f.i.
ip nat translation max-entries host 10.1.1.1 500. This user can now have 500 nat translations
