HELP - Inward NAT failing
l.d.landis
Previously posted as C2900 - inward NAT partial success...
Running C2900-UNIVERSALK8-M, Version 15.0(1)M3 RELEASE SOFTWARE (fc2)
I have several sets of inward NAT defined (51001-51007, 52001-52007. 53001-53007),
all to various internal addresses. When I attempted to add another set, the new ones
do not work and get a "timeout" error.
When I tried port 51008, it gets a timeout.  When I changed 51008 to 51010, the 51010
now gets a timeout, and 51008 now gets "connection refused" (which I expect).
The original sets all work, the new ones (added at the end of the lists) do not.
When I am on any of the internal machines, the target (192.168.1.21) works fine.
When I am "in the router", I can connect via the ssh command, so I know that the
router can talk to 192.168.1.21 on port 22 as expected.
I now have 33 "ip nat inside source static" lines (there were 30 before the new ones):
ip nat inside source list 1 interface GigabitEthernet0/0 overload
and all of the ip nat inside lines are of the form:
ip nat inside source static tcp 192.168.1.x 22 interface GigabitEthernet0/0 51xxx
where the x octet is per machine, the 22 is 22, 443 or 9234 and 51xxx is 51001-51007 or
52001-52007 or 53001-53007 and I have
access-list 1 permit 192.168.1.0 0.0.0.255
Have I overflowed some "default" limit?
The router shows things correctly (see below).
Cheers,
  --ldl
> show ip nat translations
Pro Inside global      Inside local        Outside local      Outside global
tcp 76.113.46.9:51010  192.168.1.21:22     ---                ---
tcp 76.113.46.9:52010  192.168.1.21:443    ---                ---
tcp 76.113.46.9:53010  192.168.1.21:9234   ---                ---
tcp 76.113.46.9:51007  192.168.1.21:22     ---                ---
tcp 76.113.46.9:52007  192.168.1.21:443    ---                ---
tcp 76.113.46.9:53007  192.168.1.21:9234   ---                ---
Dan Frey
I see "ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0" in your config.   This can cause high CPU and lots of memory to be used since it will try and arp for every address.    DHCP should give you a default gateway (by default), if it does not change this command to ip route 0.0.0.0 0.0.0.0 dhcp.   Clear the arp cache or reboot and see if that helps.
Dan
