Help me configure cisco 831 router interfaces please, How do I make it show all the interfaces?
manasesramos
Why does mine show this and NOT all 4 ports and 1 wan port?
Manases#sh ver
IOS (tm) C831 Software (C831-K9O3SY6-M), Version 12.3(2)XA7, RELEASE SOFTWARE (f
c3)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Tue 25-Mar-08 15:21 by ealyon
Image text-base: 0x800131E8, data-base: 0x80B77E34
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
ROM: C831 Software (C831-K9O3SY6-M), Version 12.3(2)XA7, RELEASE SOFTWARE (fc3)
Manases uptime is 52 minutes
System image file is "flash:c831-k9o3sy6-mz.123-2.XA7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
CISCO C831 (MPC857DSL) processor (revision 0x200) with 29492K/3276K bytes of mem
ory.
Processor board ID AMB065100C9 (3557975494), with hardware revision 0000
CPU rev number 7
Bridging software.
2 Ethernet/IEEE 802.3 interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Manases#
Manases#sh inter des   <---------------------------------------------------------------------------------------
Interface Status         Protocol Description
Et0       up             up
Et1       up             down     Internet WAN Port
Manases#sh ip inter bri   <---------------------------------------------------------------------------------------
Interface                  IP-Address      OK? Method Status                Prot
ocol
Ethernet0                  unassigned      YES NVRAM  up                    up
Ethernet1                  10.25.50.75     YES DHCP   up                    down
Manases#
How do I make it show all my ports? when I plug in something to port 1-4 it shows me on the log that I plug in to e0.
I  got port1-4 and 1 wan port.
9 Replies 9
Reza Sharifi
if you want to see all the interfaces issue this command
sh ip int brief
or sh run
it seems you currently have 2 interfaces e0 and e1
Et0       up             up
ocol
Manases#
yes, you only have 2 interfaces on this router
But my router has 4 interfaces and 1 wan port in the back, how do I get this router to show them?
Your router probably doesn't recognize those interfaces and that is why you don't see them in sh ip int bri
what type of interface are they?  can you describe them?  Are they on a module or build in interfaces?
What IOS ver are you running?
Manases#sh ver
c3)
Manases uptime is 1 minute
ory.
CPU rev number 7
Bridging software.
Manases#sh flash
System flash directory:
File  Length   Name/status
  1   5961996  c831-k9o3sy6-mz.123-2.XA7.bin
[5962060 bytes used, 2164404 available, 8126464 total]
Manases#sh hardware
c3)
Manases uptime is 3 minutes
export@cisco.com.
ory.
CPU rev number 7
Bridging software.
Manases#
If you google images of cisco 831 router youll see how the back looks like, and youll see all the ports im talking about.
Hi Manases. The ports on this router are showing up as e0 (LAN switch ports) and e1 (WAN port) due to the IOS version. You would have to upupgrade your IOS in order to see the ports listed individually.
I have the same router with an old image, c831-k9o3y6-mz.122-13.ZH4.bin.
It shows the ports same as yours. I upgraded to a newer IOS c831-k9o3sy6-mz.124-25d.bin and it showed the ports individualy, but then I found a book that focuses on setting up the 831 using the older image so I switched back.
If you're interested take a look at this book by Jason C. Neumann, "CISCO Routers for the Small Business". By the end of chapter 2 you should have a working/configured C831.
I hope this helps.
The IOS I got is only 5megs, the file you told me to get is 9megs, and my router can only handle 8megs
r1>sh flas
r1>
Thanks Ian, I would like to fin an IOS the my router could handle that would show me all my 4 interfaces.
Manases....
