Help me DSCP tag incoming packets on an ISR 1811 switchport
jesper_petersen
Hello peeps
I'm trying to tag all incoming packets received on a particular switchport with DSCP EF. There is a VoIP concentrator connected to that port, so I would like to tag all packets with EF, so that I can more easily prioritize them at the output interface (WAN). To my knowledge the VoIP concentrator does not tag the packets. Is there a way that I can see the tags handled by the internal switch? Like the "sh mls qos interface" on a Catalyst switch.
I have the following configuration but it does not seem to do the job:
class-map match-all MatchAllTraffic
match input-interface FastEthernet9
policy-map TagWithEF
class MatchAllTraffic
  set ip dscp ef
description VoIP concentrator
load-interval 30
spanning-tree portfast
service-policy input TagWithEF
------- Output
CFFSA#  sh policy-map interface fastEthernet 9
FastEthernet9
  Service-policy input: TagWithEF
    Class-map: MatchAllTraffic (match-all)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: input-interface FastEthernet9
      QoS Set
        dscp ef
          Packets marked 0
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
It seems like it does not like my applying the policy-map on the inbound direction?
I have also tried with an access-list (permit ip any any) instead of the "match input-interface fa9" in the Classmap clause.
Any one have any ideas why I cannot get it to work?
Best regards
Jesper
Hi ,
[later edit]
I see that you dont have any match on any of the classes.
You can try appling the policy on the SVI
Dan
Thanks for your reply.
I'm using the builtin 8-port switch that is in the Cisco 1811 router.
I have never used the switchport priority command.
Here is what I can gather that will help me to tag all incoming packets with COS 7:
RTR(config-if)#do sh run int fa9
Building configuration...
Current configuration : 165 bytes
switchport priority default 7
switchport priority override
load-interval 30
end
RTR(config-if)#do sh int fa9 switchpor
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1
Protected: false
Priority for untagged frames: 7
Override vlan tag priority: TRUE
Voice VLAN: none
Appliance trust: none
Is there a way to verify this without using Wireshark?
Thank you for your tip
Best regards
Jesper
I believe your policy described in the original post would work if applied on an L3 interface.
But my understanding is your  int fa9 is an L2 (switchport) interface only, isn't it?
So you would either have to make it na L3 (configure an IP address on it) or apply the policy on an SVI interface within the proper VLAN (i.e., int VLAN1).
I'm afraid  the switch QoS  commands would work on some standalone switches (see http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swqos.html#wp1162303 , .e.g) but not on the switch integrated into 1811 router.
BR,
Milan
