Help Multicast Nexus 7000
darrenriley5
We are currently migrating from Cisco 6500 switches to Nexus 7000 switches. I need replicate the following multicast configuration on the 6500 switches in the simplest way so Multicast is functioning on the Nexus 7000 switches.
Cisco 6500 configuration.
ip multicast-routing
interface Vlan8
description
ip address 10.128.46.2 255.255.240.0
ip helper-address 10.72.8.73
no ip redirects
ip pim dense-mode
ip route-cache flow
ip cgmp
standby 8 ip 10.128.32.1
standby 8 preempt
Please could some guidance be provided as to how we can enable multicast on the Nexus 7000 switches in the simplest form so this will continue operating.
Darren
5 Replies 5
csarto
On NX-OS PIM dense-mode is not supported.
You need to migrate to PIM-Sparse-Mode, using the concept of PIM Rendezvous Points
For a brief introduction to Multicast Concept:
www.ciscolivevirtual.com BRKMPL-1261 - IP Multicast – Concepts, Design and Troubleshooting
Also
http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_Multicast_Comparison
Just a brief config conversion the configuration on N7K (using auto-rp):
feature pim
feature interface-vlan
feature dhcp ! for DHCP-Relay / Helper Address
feature hsrp
service dhcp
ip dhcp relay
interface Vlan8
no ip redirects
ip pim sparse-mode ! enable PIM Sparse-Mode on interface
ip dhcp relay address 10.72.8.73
hsrp 8
ip 10.128.32.1
preempt
int loopback 100
description interface used for RP Address
ip add
ip pim auto-rp rp-candidate loopback100 group-list 224.0.0.0/4
ip pim auto-rp mapping-agent loopback100
ip pim auto-rp forward listen
The "ip pim auto-rp forward listen" must be configured also on others N7k in your Multicast domain.
Thanks very much for your reply this could be a life saver. Our access switches which are combination of Cisco4507RE and Cisco 3750 switches connect to the Nexus switches via layer 2 trunks. Do we need to consider any multicasdt configuration on these. Currently there isn't any.
Many Thanks
Darren
If the 4507RE and the 3750 are configured as Layer 3 switching you need to configure ip multicast routing also on them with ip pim sparse-mode under layer 3 interfaces (SVI or Routed interfaces). Otherwise igmp snooping is already active and you don't need any further configuration.
Just one final question. Am I ok to configure a secondary RP on my secondary Nexus? Am I correct in thinking  the system elects the device with the highest mapping-agent IP address?
int loopback 100
ip add
csarto
The highest candidate RP address is elected as RP for each group or range advertised.
Anyway I suggest to configure two (or more) Nexus 7k devices with the "PIM Anycast-RP" feature.
You can configure the Loopback100 on both devices with the same IP (f.i. 1.1.1.1 on N7k-1 and 1.1.1.1 on N7k-2), this is the RP address then the two devices communicate each other using another loopback IP .
In this manner you get fast convergence when a PIM Rendezvous Point (RP) router fails.
For further information rfc4610 - Anycast-RP using Protocol Independent Multicast (PIM) http://www.ietf.org/rfc/rfc4610.txt
