WDS and Cisco DHCP
Rory Hamaker
Guys (and ladies), I am banging my head on a wall trying to figure this problem out.  I have a Windows Deployment Server (WDS) running on a lan with an address of 192.168.1.x.  I am trying to PXE boot clients in the range of 192.168.9.x and i keep getting the "No Boot File Received" error.  My primary layer 3 switch is a 3560G 48 port and it is handling the routing and vlans.  There are ACL's setup but .1 is my server vlan so everything has access to that vlan.  I have also setup the option 60 on the DHCP pool on the switch to point back to my WDS server.  All of this was working great before i switched over and let the switch handle DHCP, but due to some new security concerns i am having to move this direction with DHCP.  I have posted the primary snippets of the config for the "main" switch below:
Current configuration : 23275domain-name OMITTED bytes
! Last configuration change at 22:56:58 central Sat Mar 6 1993 by
version 12.2
no service pad
service password-encryption
hostname 2097_Dev_3560
boot-start-marker
boot-end-marker
logging console emergencies
no aaa new-model
clock timezone central -6 0
system mtu routing 1500
no ip source-route
ip routing
ip domain-name OMITTED
ip name-server 192.168.1.8
ip name-server 192.168.1.78
ip dhcp pool Dev7
   network 192.168.7.0 255.255.255.0
   default-router 192.168.7.1
   dns-server 192.168.1.8 192.168.1.78
   domain-name OMITTED
   address 192.168.7.30 client-id *
ip dhcp pool Dev2
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   domain-name OMITTED
   address 192.168.2.16 client-id *
   address 192.168.2.50 client-id *
   address 192.168.2.110 client-id*
   address 192.168.2.120 client-id *
ip dhcp pool Dev4
   network 192.168.4.0 255.255.255.0
   domain-name OMITTED
   default-router 192.168.4.1
ip dhcp pool Dev5
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
   domain-name OMITTED
ip dhcp pool Dev8
   network 192.168.8.0 255.255.255.0
   domain-name OMITTED
   default-router 192.168.8.1
ip dhcp pool Dev9
   network 192.168.9.0 255.255.255.0
   default-router 192.168.9.1
   domain-name OMITTED
   option 60 ip 192.168.1.78
   option 66 ip 192.168.1.78
ip dhcp pool Dev50
   network 192.168.50.0 255.255.255.0
   domain-name OMITTED
   default-router 192.168.50.1
ip dhcp pool Dev3
   network 192.168.3.0 255.255.255.0
   domain-name *
   default-router 192.168.3.1
   address 192.168.3.3 client-id *
   address 192.168.3.4 client-id *
   address 192.168.3.5 client-id *
   address 192.168.3.6 client-id *
   address 192.168.3.7 client-id *
   address 192.168.3.8 client-id *
   address 192.168.3.9 client-id *
   address 192.168.3.10 client-id *
   address 192.168.3.11 client-id *
   address 192.168.3.26 client-id *
key chain key_rotation
key 10
  key-string 7 14343B382F2B7B7B
  accept-lifetime 00:00:00 Jan 1 2012 00:30:00 Jun 30 2030
  send-lifetime 00:00:00 Jan 1 2012 00:00:00 Jun 30 2030
key chain main
key 1
crypto pki trustpoint TP-self-signed-*
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-*
revocation-check none
rsakeypair TP-self-signed-*
crypto pki certificate chain TP-self-signed-*
certificate self-signed 01
spanning-tree mode pvst
vlan internal allocation policy ascending
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 192.168.254.254 255.255.255.0
interface GigabitEthernet0/1
switchport access vlan 6
switchport mode access
switchport port-security maximum 5
switchport port-security violation protect
spanning-tree portfast
OMITTED FOR SPACE - EACH PORT CONFIGURED LIKE PORT 1
interface GigabitEthernet0/52
switchport trunk native vlan 20
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
ip helper-address 192.168.1.8
ip helper-address 192.168.1.78
interface Vlan3
ip address 192.168.3.1 255.255.255.0
ip access-group 103 in
ip helper-address 192.168.3.1
interface Vlan4
ip address 192.168.4.1 255.255.255.0
ip access-group 104 in
interface Vlan5
ip address 192.168.5.1 255.255.255.0
ip access-group 105 in
interface Vlan6
ip address 192.168.1.254 255.255.255.0
interface Vlan7
ip address 192.168.7.1 255.255.255.0
ip access-group 107 in
interface Vlan8
ip address 192.168.8.1 255.255.255.0
ip access-group 108 in
interface Vlan9
ip address 192.168.9.1 255.255.255.0
ip access-group 109 in
interface Vlan20
no ip address
interface Vlan50
ip address 192.168.50.1 255.255.255.0
interface Vlan90
ip address 10.20.20.1 255.255.255.0
interface Vlan98
ip address 192.168.98.1 255.255.255.0
interface Vlan99
ip address 192.168.99.1 255.255.255.0
ip access-group 199 in
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip helper-address 192.168.1.6
interface Vlan710
ip address 192.168.10.1 255.255.255.0
ip access-group 110 in
router eigrp 563
redistribute static
no eigrp log-neighbor-changes
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip access-list extended SSH-Clients
ip radius source-interface Loopback0
logging esm config
access-list 3 permit any log
access-list 101 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 101 permit udp any host 255.255.255.255 eq bootps
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 102 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 102 permit udp any host 255.255.255.255 eq bootps
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip 192.168.50.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 103 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 103 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 103 permit udp any host 255.255.255.255 eq bootps
access-list 103 permit ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 104 permit ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 104 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 104 permit udp any host 255.255.255.255 eq bootps
access-list 104 permit ip 192.168.4.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 105 permit ip 192.168.5.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 105 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 105 permit udp any host 255.255.255.255 eq bootps
access-list 105 permit ip 192.168.5.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 106 permit ip 192.168.6.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 107 permit ip 192.168.7.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 107 permit ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 107 permit ip 192.168.7.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 107 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 107 permit udp any host 255.255.255.255 eq bootps
access-list 107 permit ip 192.168.7.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 108 permit ip 192.168.8.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 108 permit ip 192.168.8.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 permit ip 192.168.8.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 108 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 108 permit udp any host 255.255.255.255 eq bootps
access-list 108 permit ip 192.168.8.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 108 permit ip 192.168.8.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 109 permit ip 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 109 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 109 permit udp any host 255.255.255.255 eq bootps
access-list 109 permit ip 192.168.9.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 110 permit udp any host 255.255.255.255 eq bootps
access-list 110 permit udp any 192.168.1.0 0.0.0.255 eq bootps
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 199 deny   ip any any
banner motd ^C**************************************************************************
details removed
**************************************************************************^C
line con 0
logging synchronous
login local
line vty 0 4
access-class 3 in
login local
transport input ssh
line vty 5 15
access-class 3 in
login local
transport input ssh
ntp authentication-key 10 md5 020B055205 7
ntp authenticate
ntp trusted-key 10
ntp source Loopback0
ntp server 192.168.1.8
end
Peter Paluch
Hi Rory,
I have only very seldomly configured DHCP with PXE-enabling options. However, one thing I am missing here is the bootfile directive that should tell the PXE clients which file to download from the server and execute during the boot phase. This file has to be downloadable via TFTP from the WDS server. Sadly, I do not know what the value is supposed to be - in case you do not know, either, it may be helpful to capture and analyze the communication between a PXE client and the former DHCP server on the WDS to see the individual options and their values - and then configure them identically on Cisco DHCP server.
It should be noted, however, that even Cisco considers the DHCP server functionality in IOS as being rather simplistic and limited, and if more complex DHCP scenarios are required, you should really consider using a dedicated DHCP server.
Best regards,
Peter
