Help on Router Load Balancing????
Dear Support-Team,
Will help me to configure my 1841 router for ISP Load Balancing using static routing????
I want also configure NATing from inside to primary ISP-1 and backup ISP-2????
Please provide me reference document also...
Janardhan
skarthic
The following Cisco Doc explains configuration of ISP failover and load balancing with NAT.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
HI ,
Thanks for your reply and i will work on that.
Janardhan
On Thu, Mar 24, 2011 at 2:26 AM, skarthic <
