HELP PLEASE!!!!!!!!!!!!!!!!!!
I have a lab Configuring a switch in VTP transparent mode and i cant for the life of me get the two routers to be able to ping each other see attached
Francesco Molino
I'm sorry can't get packet tracer working on my mac. Can you share the design and configs?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
8 Replies 8
Francesco Molino
Francesco
I attached a package tracer zip file
Yes but not able to run packet tracer on my machine. That's why i asked if you could share the config and design to help you.
Francesco
Attached are the steps I went through, I will send my setup in a few minutes
Don't see nothing attached
Francesco
I think I figured it out, I didn't have the trunk configured, configured it
and then I could ping.
##- Please type your reply above this line -#
Ok thanks for letting us know
Francesco
the below would work as well (making access ports in Vlan 2010 of all links):
SW1
interface FastEthernet0/1
switchport access vlan 2010
switchport mode access
interface FastEthernet0/2
SW2
