I've set up a VPN tunnel between a 7206 router, and a rv042 vpn router. The tunnel connects, but no traffic passes.
I'm assuming this is because I need to tweek NAT, ACL, routing, etc.
I'm testing this setup out right now, but here's how it would go.
Internet via ethernet into fasteth0/0 on dhcp(works, gets an IP)
Tunnel to rv042 via fasteth 2/0(tunnel connects)
Host on switch of RV042 needs to connect over VPN tunnel to be able to get online.
Is there any guides that would help me out?
