[Help] Subnetting!!!
thienphongtran
Frequent Visitor
Frequent Visitor
I'm a newbie in this topic. My duty is separate a network into 30 subnets( without using vlan). My model is below. My needs is:
- Every L2 Switch belong to a constant and sole ip range and when i connect it to any L3 Switch then it still works with original ip.
How can I do that? please!!!
12 Replies 12
Mark Elsen
 - On a 'local Intranet' and or without a L3 boundary (router); you need Vlan's for subnetting ;
https://learningnetwork.cisco.com/thread/34441
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
@Mark Elsen isn't Multiple Switch  a  L3 Device?
 - No, multiple switches can be connected to each other, over one network (one vlan) ; if you start subnetting and create Vlan's they will be connected through trunks (which can carry mutiple-vlan-traffic too)
M.
@Mark Elsen But I can assign an IP to a port in Multiple Switch?
 - You cannot  assign an IP address to a L2 port.
M.
@Mark Elsen If its my misunderstanding, in Multiple Switch, we can use "no switchport" command to change a Port to a L3 Port?
 - Yes, you can do that , I am not sure what you mean by 'Multiple Switch' ?
M.
@Mark Elsen my mistake! its Multilayer Switch? So as my original question, Can i do that?
 - Yes,
M.
@Mark Elsen Then How to do that? I'm very new on this? also this my first duty for job!
Hello
Not sure what you mean here,can you elaborate on your requirements, as it not quite clear - What I can clarify is routed ports CAN be created from access ports but it all depends on the switch model and feature set running ( example: Lan base feature set doesn't support routed ports)
Attached is a subnetting document I complied for another post which may be able to assist in subnetting a/24 ip range
res
Paul
Kind Regards
Paul
@paul driver according to my model, i want to separate network into 30 and more subnets(i theoretically know subnet ). My need is: When i connect a computer to any L2_Switch(I name it in model), it still be active without changing its original ip. sorry my english not good.
