Help with 851w
billbmcse
Hi, need some help. Not sure if this is possible but I have an 851w and I wanted to know if the USB ports could be used to connect an external USB drive. If so, how does one do that?
Reza Sharifi
Bill,
Are you sure that the 851 has a USB port?
According to this document,
The Cisco 851 router does not have any USB ports
http://www.cisco.com/en/US/docs/routers/access/800/850/hardware/quick/guide/857qseng.html#wp1030998
Reza
