Help with ASA configuration
k.barley101
I am currently trying to build a network in a lab at ECPI and having issues connecting the ASA to the network and getting all LANs out to the internet.
The outside ip address will be 10.14.11.155 with a default gateway of 10.14.11.1
I wanted to connect the ASA to each router? or is there a better setup?
dukenuk96
Level 3
Level 3
It seems you want to simulate branch offices, so in real-life scenario it would be impossible to connect ASA to each of the routers. I would recommend the following design at least one branch:
So two ASAs and two routers for redundancy, also it would be better to use two L3 switches, but it's up to you. Having two ASAs and two routers will let you to achieve good redundancy.
