Help with Cisco 867VAE-K9 DSL Connection (Static IP) and Setup DHCP
hasan0242
Hi everyone
I'm trying to learn more about Cisco routers and doing some training along the way. I bought this Cisco 867VAE-K9 in hopes to learn about the Cisco IOS and potentially move more onto other Cisco stuff in the future. I'm currently stuck on the first point where I have to configure the router with my ISP's given static IP. ISP Config for ADSL connection:
IP: 60.242.177.122
Subnet: 255.255.255.252
Default-Gateway: 60.242.177.121
Primary DNS: 8.8.8.8
Secondary DNS: 8.8.4.4
Currently, below is how I progressed so far. I dont have any connection yet. Any suggestion will be helpful. I have attached network diagram with LAN and WAN IPs.
Router Config:
Router#sh run
Building configuration...
Current configuration : 1357 bytes
! Last configuration change at 23:31:51 UTC Sun Feb 5 2023
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
wan mode dsl
no ipv6 cef
ip source-route
ip cef
ip dhcp pool Test1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
interface Dialer1
ip address 60.242.177.122 255.255.255.252
ip default-gateway 60.242.177.121
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 60000 1000
end
Router IP:
Router#sh ip int brief
ATM0 unassigned YES unset administratively down down
Dialer1 60.242.177.122 YES manual up up
Ethernet0 unassigned YES unset administratively down down
FastEthernet0 unassigned YES unset down down
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset down down
FastEthernet3 unassigned YES unset down down
GigabitEthernet0 unassigned YES unset down down
GigabitEthernet1 unassigned YES unset administratively down down
NVI0 60.242.177.122 YES unset up up
Vlan1 unassigned YES unset down down
5 Replies 5
you need to configure basically wan mode (which you already done) and dialer interface properties. check below thread to see some configurations worked. even you have static IP, you need to configure dialer to get it. also make sure your ISP using correct DSL mode. your router does not support ISDN and it needs POTS.
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-693249.html
Good luck
KB
Hi Kasun
Thanks for your reply. I have also configured the dialier as well. How do I make sure of the correct DSL mode with my ISP?
to check supported modes, you need to contact ISP
Good luck
KB
Thanks for your reply Kasun
you are welcome
Good luck
KB
