Help with ISR4451 PAT configuration
ktuohy1987
Im trying to deploy an isr4451 with a nim-es2-8 module and am running into issues. The end goal is to provide internet connectivity for several client devices connecting to the nim module. Presently, client devices are unable to ping out nor can they browse the internet despite seeing nat translations taking place. Clients can ping the vlan 10 and loopback for R1. Please help. Config attached below:
r1#sh run
Building configuration...
Current configuration : 4196 bytes
! Last configuration change at 22:47:22 UTC Mon Mar 25 2019
version 15.5
no platform punt-keepalive disable-kernel-core
hostname r1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
enable secret 5 *****
no aaa new-model
ip name-server 8.8.8.8
ip domain name blah.com
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1
ip dhcp pool devices
network 192.168.1.0 255.255.255.0
domain-name blah.com
dns-server 8.8.8.8
default-router 192.168.1.1
lease 8
subscriber templating
username ***** privilege 15 secret 5 *****
redundancy
mode none
vlan internal allocation policy ascending
interface Loopback0
ip address 10.0.0.1 255.255.255.254
interface GigabitEthernet0/0/0
description **WANLINK**
ip address 1.1.1.1 255.255.255.252
ip nat outside
ip access-group 100 in
ip access-group 110 out
media-type sfp
negotiation auto
ip virtual-reassembly
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
interface GigabitEthernet0/1/0
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
!interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
ip nat pool outside 1.1.1.1 1.1.1.1 netmask 255.255.255.252
ip nat inside source list 10 pool outside overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip ssh source-interface Loopback0
ip ssh version 2
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 100 permit tcp any any eq 22
access-list 100 permit tcp any any eq domain
access-list 100 permit udp any any eq 22
access-list 100 permit udp any any eq domain
access-list 100 permit tcp any any eq 443
access-list 100 permit tcp any any eq 7004
access-list 100 permit tcp any any eq 7014
access-list 100 permit udp any any eq ntp
access-list 100 permit udp any any eq isakmp
access-list 100 permit udp any any eq non500-isakmp
access-list 100 permit udp any any eq 33434
access-list 100 permit udp any any eq 33435
access-list 100 permit udp any any eq 33436
access-list 100 permit ip any any
access-list 110 permit tcp any any eq 22
access-list 110 permit tcp any any eq domain
access-list 110 permit udp any any eq 22
access-list 110 permit udp any any eq domain
access-list 110 permit tcp any any eq 443
access-list 110 permit tcp any any eq 7004
access-list 110 permit tcp any any eq 7014
access-list 110 permit udp any any eq ntp
access-list 110 permit udp any any eq isakmp
access-list 110 permit udp any any eq non500-isakmp
access-list 110 permit udp any any eq 33434
access-list 110 permit udp any any eq 33435
access-list 110 permit udp any any eq 33436
access-list 110 permit ip any any
control-plane
line con 0
stopbits 1
login local
line aux 0
stopbits 1
line vty 0 4
login local
end
Many Thanks!!
7 Replies 7
balaji.bandi
Before we build advanced rules, we need to see the basic config working or not.
So lets start tweak the basic config, if it working then we go to next level. (if not thing will be complicate to diagonsis)
here is my personal suggetion :
ip nat outside
no ip access-group 100 in  <-- remove this for basic testing
no ip access-group 110 out <-- remove this for basic testing
media-type sfp
negotiation auto
interface Vlan10
ip nat inside
ip nat pool outside-net 1.1.1.1 1.1.1.1 netmask 255.255.255.252  <--- changed name not to confuse outside interface or outside pool
ip nat inside source list 10 pool outside-net overload
no ip http server
ip ssh version 2
change above advise and test & advise
BB
Deepak Kumar
Please make below changes:
ip nat outside
media-type sfp
negotiation auto
no  ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
A few changes are required.
conf t
no ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 gig0/0  1.1.1.2  <---needs to be your wan next hop ip address
dns-server 8.8.8.8  208.67.222.222 208.67.220.220
interface GigabitEthernet0/0 ---<--no need for your access list as you are permitting with ip any any in both listings anyway
no p access-group 110 in
Kind Regards
Paul
My apologies. I seemed to have fat fingered the next hop address on the bucket route when I sanitized the config. It is currently set to the next hop ip.
What ive done:
-I changed the nat config to reflect the pool name outside-net per Balaji
-Removed inbound and outbound ACLs on gi0/0/0
-Modifed bucket route to use interface gi0/0/0 instead of next hop IP however this breaks ping completely from the router. When I use the route ip route 0.0.0.0 0.0.0.0 1.1.1.2 I can ping the next hop and 8.8.8.8 but nothing else
I found an issue with the next hop IP that I corrected and I can now ping out from the switch by IP and FQDN.
However, client devices still are not able to browse the web. The client device can ping all the way out and I can see DNS resoltuions taking place in the NAT tables but still clients cant browse.
Current config below:
r1#sh run
Current configuration : 4248 bytes
! Last configuration change at 15:14:02 UTC Tue Mar 26 2019 by build
version 15.5
hostname r1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging console
no aaa new-model
ip name-server 208.67.222.222 208.67.220.220
dns-server 208.67.222.222 208.67.220.220
lease 8
license udi pid ISR4451-X/K9 sn FOC22396AQM
username **** privilege 15 secret 5 ****
redundancy
mode none
interface Loopback0
ip nat outside
media-type sfp
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
no ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 1.1.1.2
ip ssh version 2
control-plane
line con 0
login local
stopbits 1
line aux 0
 stopbits 1
line vty 0 4
login local
end
What is IP on your PC and share switch configuration as well?
Deepak Kumar
Deepak Kumar,
is this DNS Server reachable ? dns-server 208.67.222.222 208.67.220.220
From clients, is this windows box,
Can you post from your windows client  ipconfig  /all
From windows client post the output below information
nslookup google.com
nslookup cisoc.com
ping this ip 208.67.222.222 208.67.220.220
have you tried setup a dns at client 8.8.8.8 ?
BB
