Help with Link Aggregation
yahyaa.bham
Visitor
need some help getting this going..
I have 2 SG500 switches in L3 mode, stacked, that will act as my main router.
I then have several SG500 switches in L2 mode dotted around the business.
I'm looking to cable 2 ports from each of the L3 switches to the L2 switches for redundancy.
How would i go about setting this up? I have set the vlans on the L3, set up GVRP on both L3 and L2, put the 2 ports on the L3 in lag 1.
Reza Sharifi
Have never used the SG series before but if they are like any other Cisco switches, they should support Portchannel or EtherChannel for aggregating multiple physical links using LACP/PAGP or mode on.
