Help with NAT
AnthonyDunn2010
Hi All,
need help with nat setup, so my setup is as follows (just on packet tracer), i have 4 routers which can be seen below , R1, R2, R3 and the Gateway 1.1.1.1 which is supposed to be my isp. so will refer to it as ISP.
If i ignore R2, and concentrate on R1 setup.
R1 has two interfaces, one connects to 192.168.1.0/23 network with ip 192.168.1.1 which goes to the switch and then has another interface which is on a
10.10.10.0/30 subnet with IP 10.10.10.6
R3 also has two interfaces, again 10.10.10.0/30 with ip 10.10.10.5 , communication between R1 and R3 is fine
R3 other interface is on a serial connection with network 1.1.1.0/30 and ip 1.1.1.2 , which connects to the ISP router
ISP router only has one interface subnet 1.1.1.0/30 , ip 1.1.1.1
R3 and the ISP can ping between each other, but R1 cannot ping the ISP
I added a route to the isp for the 10.10.10.0/24 network to go to 1.1.1.2 and then pings worked fine.
But in real world this would not happen, i want to simulate NAT so that when i ping from R1 , it hits its default gateway which is R3 , then R3 NATs the traffic out on its 1.1.1.2 address, then NATs it back on the incoming to the 10.10.10.0/24 network?
I've tried various things and read a fair few articles but still not getting anywhere
R3 and ISP are connected both on serial2/0
R1 and R3 are conencted via R3 fastEthernet1/0 and R1 Gigabitethernet0/2
R1 does have the route 0.0.0.0 0.0.0.0 10.10.10.5 in its config and R3 has same except routes to 1.1.1.1
can someone please explain the commands i would need to put into all the routers to get NAT working correctly?
Configs are below incase anyone wants a flick through, and thank you for taking the time to read and reply.
R1 config
Current configuration : 858 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Router
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524R5SC
spanning-tree mode pvst
interface GigabitEthernet0/0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
ip address 10.10.10.6 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.5
ip flow-export version 9
line con 0
exec-timeout 0 0
password 7 0822455D0A16
logging synchronous
line aux 0
line vty 0 4
login
end
R3 config
Current configuration : 957 bytes
version 12.2
hostname Router
ip cef
no ipv6 cef
interface FastEthernet0/0
 ip address 10.10.10.1 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet1/0
 ip address 10.10.10.5 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
interface Serial2/0
 ip address 1.1.1.2 255.255.255.252
 ip nat inside
 clock rate 2000000
interface Serial3/0
 no ip address
 clock rate 2000000
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 1.1.1.1
line con 0
 exec-timeout 0 0
 logging synchronous
 login
line aux 0
line vty 0 4
 login
end
ISP Router config
Current configuration : 996 bytes
version 12.2
hostname Router
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 1.1.1.1 255.255.255.252
interface Serial3/0
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
interface Serial6/0
no ip address
shutdown
interface Serial7/0
no ip address
shutdown
interface Serial8/0
no ip address
shutdown
interface Serial9/0
no ip address
shutdown
ip classless
line con 0
exec-timeout 0 0
logging synchronous
login
line aux 0
line vty 0 4
login
end
AnthonyDunn2010
Hi Gusy,
i managed to get this working creating a nat pool and an access list, then put the ip nat outside on serial2/0
and ip ant inside on the two fast ethernet ports
access-list was setup to accept all from 10.10.10.0 0.0.0.255
and pool was just on the one ip 1.1.1.2
But since putting this in, all is working!
