help with Packet Tracer activity
julio96
I wanted help for an activity where I did everything, but something went wrong I can't ping between the pc hosts
 Some checks you need to perform.
You twisted the PCs on the FILIAL-01.  They are on the wrong vlan. Need to fix
You need to setup ip address on the router interface if you want to ping from  FILIAL-01 to Sede.
All interface between switch need to be in trunk. (All of them).
You can not have the same network on Sede and Filial...otherwise you can not ping.
Pode escrever em portugues, se quiser.
meu deus do céu cara, muito obrigado, to o dia todo nisso kkkkkkkkkkkk e era só essa parte ai do trunking, a parte de rotear não precisa pq o professor errou o enunciado ai cancelou essa parte, era só pigar mermo
Sempre que precisar pode trazer as dúvidas aqui no fórum.
 Tem muita gente fera em cisco aqui.
Bons estudos!!
