BPDU issue
ssnachy0
Community Member
using SG 300 switch getting very frequent access port error disabled due to the BPDU
okay !! then disable PBDU or uninstall software that is creating flooding.
Jitendra
Jitendra
5 Replies 5
Jitendra Kumar
is there PC connected with the port or any other device.??
Jitendra
Jitendra
yes user connecting there his windows laptop.
Scan their system must be having some software so that flooding happens.
Jitendra
Jitendra
he is using Wireshark and some other software for testing purposes.
Jitendra
Jitendra
