help with paket tracer routes
Al3xX995
Hello everyone. I am trying to set up default/static routes for a lab i made in packet tracer. I have two different lan's connected with two routers.I need to ping from the "voice toys server" to the wired end device, located in the second lan. I've tried to set static routes but the ping fails every time, not even leaving the server. Can someone help me?thanks in advance. I'll attach a jpg of the lab.
luis_cordova
Hi @Al3xX995 ,
I enclose the exercise with the correction of one of the networks and with the static routes configured.
luis_cordova
Hi @Al3xX995 ,
The proposed networks, highlighted in the red boxes, overlap each other.
This means that the ping sent from one end does not go out, because the router finds the configured network in one of its own interfaces.
I suggest you see the possibility of changing one of these two networks to prevent them from overlapping.
Once the change is made, only the static routes will remain.
luis_cordova
Hi @Al3xX995 ,
